Engine Transplants?
Engine Transplants?
Thank you received: 794
3 years 2 months ago #231202
thats the fun bit finding a engine that will give the torque needed at low enough revs.
a c15 could work in some applications as they are 500hp and prefer to work around 1300 rpm. the 2 stroke gm loved to work 1800 to 2100.
anything is possible if you can get or build reduction gearing and adapters suitably strong enough.
Thank you received: 90
3 years 2 months ago #231203
by kittyman1
yes there's a ton of variables involved... its not totally about can i lug at 1200-1300 RPM is it??
-it seems many diesels are efficient in the 1800- 2000 RPM range....(not gospel)
doesn't HP = RPM x Torque divided by 5252?
3 years 2 months ago - 3 years 2 months ago #231204
yes thats the formula. these old girls did it by having large conrods so more torque for a given rpm.
the c series cats in trucks when coupled to a 18sp eaton trans they would work em between 1200 and 1800 always trying to maintain around 1300 to 1650 rpm the sweet spot around 1500
3 years 1 month ago #231722
by kittyman1
-not sure if tons of metal flying around translates into more power at the flywheel...or a different kind of torque/ power delivered to finals etc....and more work done...?
-maybe some are totally underestimating what a 855 Cummins can do, ...work done per barrel etc... (Hint it not a slouch)
Thank you received: 663
3 years 1 month ago - 3 years 1 month ago #231732
Torque has a strong relationship with stroke, as does rpm. If you browse for an engine where the rpm you want is about midway between the torque and hp peaks for an engine, that would make a good match. You'd need to look through spec sheets to find one that was suitable. You could also consider the fuel rate against the rpm if you really wanted to fine-tune the selection, for good economy.
For replacements, you're looking for a reasonably close match on torque and rpm, hp to some extent, and form factor particularly if you want an easy installation. The easiest replacement is the exact same engine. The best fuel rate for work done is usually when the engine is operating at load about halfway between the torque peak and rated power. For a lot of the 14 to 19l engines from back in the day, this was usually around 1600 to 1800rpm. You have to factor that into the gearing of the machine you're transplanting into. Two-cycle Detroits, although smaller, often also had a torque peak around 1400 and a rated speed of 2100 so they ran best in that range too. This is probably why they were a popular transplant engine.
John Deere had a ~900ci V8 in their 8850 tractor - JD being JD, parts are as expensive as heck, so a company had a decent sideline fitting Cummins into them when the V8 gave out, so anything can be done of course but the effort goes way up sometimes when the replacement is non-original__PRESENT
Last edit: 3 years 1 month ago by
neil.
3 years 1 month ago #231750
its all about leverage in essence a con rod is basically a big lever so the longer the lever the more force can be generated the larger the distance from crank centre to big end centre the more leverage so more torque as well.
yes you can have a engine that revs hard and make a lot of hp due to the rpm but it will be shit at shear pulling power because it doesn't have the torque.
where in the rev range a engine makes torque has a hell of a lot to do with how good it is at the task required. and to change that can be as simple as changing the camshaft.
8C 361
Thank you received: 141
3 years 1 month ago #231764
by Wombat
The original post was to just repower something like a D8 with a smaller higher revving engine. How anyone would think a14 liter engine will handle producing enough horsepower and torque at much lower than its rated optimum revs and match 20 liters I am not sure. Those D342 engines are large, heavy and slow revving, an 855 Cummins needs to be running at much higher revs that do not match the gearing etc of a D8.
I have seen an old Ford V8 installed into an early D4, it made a lot of noise with lots of revs and just died when the load came on, had no hope in hell of matching what the old original slow revving engine did. If the question then becomes how many other modifications would have to be made to install a smaller high revving engine, what gearing etc would have to be fooled with, in the end why bother? Tractors fitted with smaller high revving engines are designed with gearing so that they work effectively..
I had a D8L that the governor and fuel settings got out of whack over time due to wear, revs went up, governor fuel dropped, they mismatched torque converter pressures, result wouldn't push the skin off a rice custard. It took about five hours to adjust it all to the top allowable settings, it then made the D9N running beside it to work harder to keep up, it obviously then needed the same treatment.
I always believed in the philosophy that if you are going to re power, use an identical or near identical engine to get best results. Just turning up fuel is not always the solution, I have had many Mack owners tell me an EM9400 will run with a E9500, that the 500 does not really gain much in a day pulling the same loads.
Wombat
Thank you received: 47
3 years 1 month ago #231770
by 8C 361
Remember that guy south 40 ? I think he had a HT4 chassis he put various engines in whilst he left his original engine laying in pig slop? I think he had a Ford/cornbinder engine it it for a while.
Steve A
3 years 1 month ago #231779
by kittyman1
close Wombat, but not quite...
-of course there is no way 14 litres can produce the power of 20 litres at the same RPM...the gearing would have to correct and it probably wouldn't be feasible to do that
-that's why i mentioned the HP formula, as far as i know 300 flywheel horsepower is 300 flywheel horsepower, no matter the cubic inches or strokes or RPM, or how you get there..
-a friend of my dad had several D7e and a D8 back in the 80s and 90s, then he switched to Komatsu 85, had 3 of them....he thought they were the greatest thing ever, that's where the 14L Cummins idea came from...
Engine Transplants?
Time to create page: 0.210 seconds
