Pony piston rings
Pony piston rings
Thank you received: 16
3 years 2 months ago #231079
by D2Fred
When you order piston rings and bearings for the pony motor on a d2, are the rings packaged one ring in a box? Are the rod bearings one half or both halves? Is there a source other than the dealer? One ring for 13 bucks is pretty expensive!
Thank you received: 276
3 years 2 months ago #231080
by rax200
Hi D2Fred,
The rings are supplied one ring per box so 8 boxes, and for the bearings it is packed two shells in the one box, so 2 required.
Have you tried Florin Tractors as Dana might have some.
Regareds
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
D2Fred
Thank you received: 324
3 years 2 months ago #231088
by Ray54
Pony motors have never been known to be a cheap starter on the old Cats. I had near a $1000 in a D6 pony in the early 90's. For a working tractor I should of put the direct start kit on it.
Thank you received: 794
3 years 2 months ago #231113
you order rings as a set. not individually unless they are listed as individual part numbers in the parts book. which also often has the quantity required listed too.
take a piston into your local rebuild shop they may be able to match up a set of rings for you. i have a air compressor that has mazda rings in it. they could probably do bigend shells too.
and a family friend had austin healy engine with 179 holden red motor pistons and rings when they bored it out to the maximum the 179 pistons fit perfectly, when they finish hotting it up it would take on 351 powered fords. many engines used the same size parts as others did.
D2Fred
Pony piston rings
Time to create page: 0.136 seconds
