D17000 connection
3 years 3 months ago - 3 years 3 months ago #230548 by hfdzl
D17000 connection was created by hfdzl
Would anyone have information on a D17000 generator part #6F1956, serial # 6805674 ?  How is the DC exciter connected? Will the generator  make power just as it is? I found 5 non Cat wires connected to a switch with capacitor that was operated by  the throttle control. What does that do? It was not connected to the generator. The genset is connected low voltage with neutral. 120/240 v
Thanks, Herb
R2 5E3562 SP U.S.A. W.9151
R2 5E3563 SP U.S.A. W.9152
Last edit: 3 years 3 months ago by hfdzl.
3 years 3 months ago - 3 years 3 months ago #230552 by hfdzl
Replied by hfdzl on topic D17000 connection
Beating my head many times against hard surfaces, I found the information I needed. The box is a Modutrol control. This is a motor that controls the governor on the generator from a remote location, ie service panel. I remember them from way back for boiler controls, probably obsolete with the electronics updates now. Sometimes I just have to let the internal computer settle down and spin around for a while!
I still would need the connection for the DC exciter.
Thanks for looking, Herb.
3 years 3 months ago #230579 by edb
Replied by edb on topic D17000 connection
Hi Herb,
sorry mate but it helps immensely if you keep all posts relating to a particular machine in one thread as I had to trawl back some 5 pages to see a picture of your unit to check which Generator Set unit you had.
Hope the scans help some.
Regards,
Eddie B..
3 years 3 months ago #230582 by Old Magnet
Replied by Old Magnet on topic D17000 connection
It would appear that your generator was set up for remote manual voltage control.
Here is the wiring diagram.
3 years 3 months ago #230583 by hfdzl
Thank you for this valuable info.! Now I can get this sorted properly.
Thanks, Herb
3 years 3 months ago #230590 by hfdzl
So to have this unit be self regulating , the original Caterpillar throttle linkage would have to be replaced? Or would have to be manually adjusted for output?
Thanks, Herb
3 years 3 months ago #230591 by Old Magnet
The engine throttle control would still be used to set up the engine running on governor control then switched to automatic (self) regulation. Final voltage will still be controlled/set by the remote Exciter Rheostat.l
3 years 3 months ago #230592 by hfdzl
This setup probably never be used as standby power use. I would like to take it shows, having to be able to run with a few light bulbs to show that it does make power. The less hardware, switches, cabinets etc would be better. A main switch that controls the load is all I need.
Thanks, Herb
3 years 3 months ago #230596 by Old Magnet
You haven't talked about starting...but be aware that the electric pony starter for the D17000 has a position switch on - off and in between. In the in between position, switch vertical, the starter motor will rotate at a slow speed to allow engagement of the pinion. Caution warning about engaging pinion at full speed.
3 years 3 months ago #230604 by edb
just to add some more scans that may be of interest.
The following user(s) said Thank You: hfdzl
Time to create page: 0.211 seconds
