Cat D318 Water Pump
Cat D318 Water Pump
Showing 1 to 7 of 7 results
Daytonengines
Send a private message to Daytonengines
How do you rebuild these water pumps? Do you do it yourself? Do you exchange the whole pump? If so, where do you exchange them? Can you buy a rebuild kit? I have had this engine since last fall and apparently it has been sitting without water in it for a long time. I have now had water in it for about 6 months and went to start it up again and now the water pump is leaking thru the weep hole.
Mon, Aug 25, 2008 12:13 AM
SJ
Send a private message to SJ
They are a very simple pump to work on and you would need a puller for the impeller but the rest is simple. Probably all it will need is the seals and possibly an impeller unless it can be salvaged again.I don,t know if kits are available or not but really all there is are a couple gaskets for the pump and a couple more to install it back on.Maybe someone on here knows of some aftermaket parts supplier or even a good used pump but then again your taking a chance how long it will hold up or is good at all.If your not capable of taking it apart any good handyman mechanic or garage could do it.Where is Dayton Pa., I looked on the map and don,t see it listed as I live here in NE Pa. near Wilkes Barre.
Mon, Aug 25, 2008 12:58 AM
Main thing is don't pull the whole rear of the pump/thermostat housing etc off the engine, just unbolt the guts of the pump and remove the fan to take it out the front.
I did one on the track of our 9U one day. Bought the seal from CAT and put it in. The seal isn't anything unusual, just a carbon seal riding on a ceramic seat. When they sit for a long time, the carbon ring can stick on the ceramic and when you turn the engine, it may crack the carbon. That will be a big leak usually.
Cat price isn't likely to be too bad unless you compare it to the $10-15 you might pay for a similar seal from a pump or industrial supply house. It won't break you to get it from CAT and it will be the right one the first time.
Mon, Aug 25, 2008 1:51 AM
SJ
CC, the earlier impeller was just metal to the seal but in little later years Cat wet to the ceramtic seal surface on the impeller where it rides against the seal.He will have to check and see which his has in it and usually if the impeller is all metal chances are it,s worn beyond using over again.I have rebuilt dozens of them over the years on various engines and the older ones were pretty much the same setup on the impeller and seal assem. back then.Sometimes the impeller can be smoothed up if it isn,t worn too much.It was a good improvement when they went to the impeller with the ceramic seal attached to it for a replacement.
Mon, Aug 25, 2008 2:22 AM
Reply to SJ:
SJ, I got to thinking and I can't remember is the seat is ceramic or polished metal (silicon carbide?). Either way, I know it's hard on them to sit for months sometimes and then start up. Ours that failed that way had shattered the carbon seal ring so it was really leaking fast!
Might be possible to machine the impeller to take a seat if it's worn too bad. Just have to cut it back enough to take care of the thickness of the washer. Looking at the parts book, I don't see any separate seat, they show a
4F4769 seal assembly consisting of-
2H560 bellows assembly (does this include the carbon ring?)
5F9140 washer (seat or carbon ring?, can't tell from the parts book picture)
Impeller is 4F5995
Mon, Aug 25, 2008 3:08 AM
Impeller is 4F5995
The carbon ring seal seat is the impeller. No fancy seat here.
Mon, Aug 25, 2008 9:37 AM
justus
Send a private message to justus
Hello,
I live on a boat, build in 1903 in the Netherlands. In 1954 a Cat was build in, a D318. Wonderfull machine...
Now the mechanical seal of the cooling water pump is rotten, so I have to replace it. As you all write it's not too hard if you have the right parts, but that's my problem. What parts to get? Any numbers? Where to get it? Any hints on getting the rotten one out, without damaging the rest?
Thanks in advance.
Justus Beth
Thu, Jun 23, 2016 4:04 AM
Reply to justus:
Hello,
Thanks in advance.
Justus Beth
Servicing the raw water pump is described in the "Servicemen's Reference Book" for the D318 engine "Form # 30238-2. You have the parts diagram. Try Cat for the parts and replace both the oil seal and water side seal.
Thu, Jun 23, 2016 6:15 AM
Newby Hall Tractor Fest
