L Twenty Pin.
3 years 3 months ago #230255 by Lance Jones
L Twenty Pin. was created by Lance Jones
Looking for suggestions for Replacement Gudgeon [Wrist]  Pin for My Big TWENTY. [L971] ,anybody got Ideas? 1.5" Diameter , It was suggested to Me that 3208 Pins may fit , Anything too long We can soon Shorten.. What a battle to remove Engine, Removing Crank was a real Battle , Too remove Shaft One has to remove centre and Rear main Bearing Studs, And someone had done a Rebuild Years ago and Locktited them in, a grey Colour and near impossible to Undo even with Heat Took us Hours . Fortunately We have obtained Sleeves the exact Length and at a reasonable price , Shaft has been Ground and now getting Rods and Bearings Rebabbited. Any ideas appreciated  LJ.
3 years 3 months ago #230259 by edb
Replied by edb on topic L Twenty Pin.
Hi Lance,
my 2Z 3208 Truck Engine manual specs say that the new piston pin size is :- 1.4999 +/- 0.0002"----sorry no length given but the 3208 is a 4.5" bore so likely the pins are some 1.5" shorter than that.
Hopefully someone can get closer in length.
The following user(s) said Thank You: Lance Jones
3 years 3 months ago #230262 by trainzkid88
Replied by trainzkid88 on topic L Twenty Pin.
loctite threadloc isnt grey it is green,blue, red, purple or brown and will release when heated to the correct temp. but you have to heat the right part as heating a stud can make it tighter due to thermal expansion.
it might have been devcon or loctite metal filled epoxy adhesive which is grey no wonder it wouldn't undo.and the compleatly wrong product.
i dont know if the gudgeon pins are case hardened. you could simply get some high grade bright shaft and turn some up on a lathe and then get those hardened or nitrided. using pins from another engine be careful if having to cut them as the heat from cutting could destroy the hardening and hardened steel has to be abrasive cut or thermally cut.
3 years 3 months ago #230273 by side-seat
Replied by side-seat on topic L Twenty Pin.
Make one. I made a set for my Twenty Eight 23years ago. I used StreesProof steel turned it in my lathe then ground it to fit the worn pistons .
You could use 4140 TGP (Turned Ground and Polished) If you have a good fit in the piston. Rod bushings you make new then size with a Sunnen Rod Hone for exact fit.
3 years 3 months ago #230393 by Lance Jones
Replied by Lance Jones on topic L Twenty Pin.
Thank You everyone for Help and suggestions , I have talked with My Engine Man and He said He would do a Cold cut and It won't affect its performance, Eddie would You have the Part Number for those Pins ? I don't have any Books for Modern Machines .If We get out of Covid Lockdown today I shall be taking Crank to Toowoomba for Babbitt work ,Tomorrow.. Trying to get My way into Gearbox now and 1 Final has a Problem , Twenty's are not the best in that Department, Rebuilt one years ago., so been there done that , only problem is remembering it all.!! LJ
3 years 3 months ago #230394 by edb
Hi Lance,
my 1Z1-up 3208 Marine Engine parts book shows the piston pin P/No as 7N9803.
3 years 3 months ago #230683 by Lance Jones
Thank You Eddie, Today I received some Genuine Pins from RD Williams in Bris. They are a couple Thou Larger than the original Pin which is Great . My Bushes are Good so wont be a Big Job to Snug Fit . They are a little shorter by.300 But We will either put a Circlip in or Pack washer to be Snug. Thanks for Your Help very Much appreciated . LJ
