D2 5U crankcase guard - need info
3 years 4 months ago - 3 years 4 months ago #230083 by neil
Hi all, I have a belly pan on my 5U13753. I need the dimensions on the two pairs of spacers - 1B8074 which are the six spacers for the bracket that bolts to the flywheel housing that holds up the center of the belly pan, and 1H0532 which are the two long spacers on the back of the belly pan that attach to the drawbar front bracket. The bolts that pass through these spacers are 1/2" so I'd think that the ID would be a bit over 1/2" but one source stated that the ID of the 1B8074 was 36mm which is about an inch and a half. Cat parts show 1B8074 in stock so I think I can get them but not sure about 1H0532 so I might have to make them up - just need the dimensions.
Also, need the latest part number for bolt 1/2-13 x 2 1/2 long - book says 3322-A__PRESENT
Last edit: 3 years 4 months ago by neil.
3 years 4 months ago #230088 by Rome K/G
Bolts are 9S1366
3 years 4 months ago #230089 by neil
Thanks Gary
3 years 4 months ago #230095 by rax200
Hi All,
For your older numbers like 3322A what you do it tell the cat parts man or when looking on the cat parts store add zero's to the front of it, it will then look like this 0003322 and drop the A.
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
3 years 4 months ago #230101 by neil
When I looked up 3322-A on Peter C's scan, it shows a 1/2-13 x 2 1/2 capscrew. According to Craig's post, the same dimension item is a 7X0325, so I wonder if Gary's 9S1366 is a further supercession? Anyhoo, I'm going to call Cat and get it sorted out
3 years 4 months ago #230104 by Ray54
A year or so by going to "One Safe Source" which Cat had online then you could find a part number of all fasteners and other hardware items Cat was currently selling.
3 years 4 months ago #230107 by side-seat
I think you have to add a prefix "0" to the prefix to cross into CAT's system?
We have a couple projects that are going to take a lot of CAT fasteners. Pretty pricey hardware. I remember spending around $350-400 to reassemble my little Terracer grader.
You do get what you pay for though.
Anything I've encountered on tractors that are 90+- years old, all of the bolts have come out unless someone put some inferior GR5 bolts in.
3 years 4 months ago #230108 by Rome K/G
7X0325 is a Zinc Dichromate Plated bolt. 9S1366 is Phosphate & Oil Coated bolt
3 years 4 months ago #230110 by neil
Gondang it, five times I tried to post exactly what Gary posted. Anyhoo, that's what the Catman said so I went ahead and confirmed the 9 Sierra 1366
