Ferrule and grommet placement in head
Gary Morisoli
Send a private message to Gary Morisoli
I am ready to install the head on the D2 4U.  Is it best to put the ferrules and grommets in the head or on the block?  Also planning to get some Prematex super 300 to coat both sides of a new head gasket.  Am I on the right track?  Thank You for any ideas,  Gary
Wed, Jun 30, 2021 10:30 AM
kittyman1
not sure, absolutely do not know the gasket material..composition...or Prematex super 300 qualities..we need more info..
-for the record, i'm not a fan of GOOPING up a quality gasket of any kind..your mileage may vary
Wed, Jun 30, 2021 1:49 PM
Thank you received: 10
Reply to kittyman1:
Hi Gary, I put the ferrules and o-rings in the head, and did not apply anything to the head gasket. I don't have any leaks and had no problem fitting the head. I can't say though whether the other options are better
Wed, Jun 30, 2021 6:56 PM
On the block, as mentioned in D311 service maual page 144, larger side of seal towards block and use the Permatex 300
Wed, Jun 30, 2021 8:18 PM
Gary Morisoli
I have the manual but missed that paragraph. I re read it and you are correct. Thank You,
Wed, Jun 30, 2021 8:55 PM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
