That's nice to know Neil, there are times I over think things, and definitely times when I over repair my old dead Cats, for example replacing every bearing in a gearbox when I find one bearing not quite right, crazy really, and a waste of money realistically, because my old girls are lucky to get driven 5 hours a year on average, but I figure while I've got a gearbox apart, or final drive, or waterpump, the cost of the extra bearings is usually only $20-$200, and much easier to fit them at the same time and sleep easy at night.
This D4 7J is a bit different to my other "boat anchors", it has done around 40 hours solid work this past year since I replaced the cylinder liners and fitted new rings along with a reconditioned head, I wanted to bed in those new parts and so used it to pull my 9 tyne chisel plough, that plough is a good solid pull in 4th gear, perfect for bedding in new rings, and the tractor runs great and makes no odd noises.
Where I screwed up is I decided I wanted to know what the actual oil pressure was when the tractor was running, so I removed my NOS Cat oil pressure gauge made in 1962, that only has a red zone or a green zone on the face, and replaced it with a fancy oil pressure gauge that shows the pressure in actual pounds, big mistake, because previously that NOS red zone / green zone gauge was always in the green zone when the diesel motor was running, cold oil or hot oil, at low idle and high idle, but with the fancy pressure gauge I was seeing the actual oil pressure, and seeing it flickering at low idle between 0 and 5 pounds scared me.
You will have seen that old Cat Tech Sheet Eddie uploaded a few times over the years, from the 1960's, where Cat talk about the actual oil pressure of their engines and the "new" style red zone / green zone oil pressure gauges that replaced the older actual pressure indicating gauges. From memory Cat said the new gauges would register in the green zone at anything from 5 pounds pressure and above, and that 5 pounds was plenty for their engines.
I was talking to Eddie Bedwell about this recently and he reminded me that oil pressure gauges that show the actual pressure are really only accurate in their middle measuring range, they are not particularly accurate at the lower and higher ends of the dial, so maybe I should just refit my old bearings, along with my nice new 1962 NOS red zone / green zone oil gauge, fill the motor with some 50W oil and get on with my life if I can't find any undersize bearings.
D4Jim, thanks for that link, very interesting, I've always thought oil get's thinner as it heats up, that's why we change it when the engine is hot, but when I talk to people about 15W40, like I use in my Case tractor and Landcruiser truck, I get told the 15 is the "thickness" of the oil when it is cold, so it flows quickly around the engine when it's cold, and the 40 is the "thickness" when the oil is hot, but that seems the reverse to what I see, maybe you can explain it better.
Mike
