D6C recommended oils
Xtremist
Send a private message to Xtremist
hey guys, just bought a d6c (96j) and was wondering what the best oil for the engine, final drives and transmission
(powershift) are.  Ive heard lots of guys say 30w and lots say 15/40 in the crankcase.
thanks
Sat, Jun 12, 2021 4:49 AM
Phillips makes oils for older machines, they have a 10W Powerdrive Hydraulic Fluid for the vane type hydraulic pumps and a 50W Powerdrive Fluid/gear oil for the final drives. I use Kendall Super D 15W40 in the engines. I use Cat 30W Drive Train Oil in the transmissions. Find a oil distributor in your area, they can get you other brands also. Also depends on your climate, use the proper viscosity oils for your temps.
Sat, Jun 12, 2021 7:42 AM
Thank you received: 32
nearly all oil companies have a tech advisory service ring your chosen company and get a recommendation. virtually all engines where SAE 30 was recommended can use a 15w40 multi-grade diesel oil and for caltex that is delo gold multi 15w40 there is also a mono grade. multi grades have replaced mono grade in most applications as there is no need to change oil for winter operation and then change it again for summer use. unless of course you are in really cold areas in winter.
Sat, Jun 12, 2021 9:09 AM
Xtremist
Reply to trainzkid88:
central alberta, -40 celsius isnt uncommon lol but likely i wont be needing to start it in those tmps and if it was an emerg i could hoard it in and use a herman nelson to warm it up.
Sat, Jun 12, 2021 10:35 AM
kittyman1
Reply to Xtremist:
central Alberta...not far from me....5w-30...10w-30 will get er'done....if operating hard in summer, higher temps etc...15w-40....
Sat, Jun 12, 2021 1:05 PM
