D4 hydralic system
D4 hydralic system
3 years 6 months ago #228260
by Ttophoven
What oil is best to use in a late 40's D4 hydralic system? No info in the maintenance manual I have.
Thank you received: 405
3 years 6 months ago #228262
by D4Jim
My 40 hydraulic scraper manual says to use crankcase oil. I use John Deere hydraulic / transmission oil in the D4 hydraulics and scraper now. Never had any seal or pump problems.
ACMOC Member 27 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
Thank you received: 120
3 years 6 months ago - 3 years 6 months ago #228263
by willwingo
You don't say what brand/ model of hydraulic system you have, if it is a Caterpillar # 44, form 31677-1, Operations and Maintenance Instructions, says to use "Crankcase Lubricating Oil" in compliance with specifications. Above 10* f, it says use S.A.E. No. 10W.
If you have a 4A or 4S Bulldozer the total capacity is 8 US gallons (44 Hydraulic control is 3 1/2 gallons and the 4A/S system is 4 1/2 US gallons).
Last edit: 3 years 6 months ago by
willwingo.
Thank you received: 820
Thank you received: 795
3 years 6 months ago - 3 years 6 months ago #228334
you can use the same oil as the engine. or do what i do and use universal tractor and harvester driveline oil. the product i use is caltex textrans tdh it is made for the trans diferential and hydraulics of most tractors and specifically for caseIH/austoft harvesters and infield transporters. it has cat TO4 approvals. and that is the caltex recconmendation delo gold 15w40 or textrans tdh which is also suitable for the transmission.
Thank you received: 999
3 years 6 months ago #228351
by Rome K/G
I switched to Betty Crocker vegetable oil, if i blow a hose it wont hurt the environment and the used oil is for frying fish.
3 years 6 months ago #228358
by D4Jim
Good one Rome!!
D47U 1950 #10164
Thank you received: 236
3 years 6 months ago #228366
by d2gary
Hahaha
So l guess if you don't follow Cat recommendations you can use whatever you want. I would use the fryer oil that cooked the fish then when you're working you could smell the aroma when everything heated up
Thank you received: 663
3 years 6 months ago #228381
If you're like the old geezers, you can put your lunch on the manifold at about 11:45 for a nice, toasty hot lunch!
Thank you received: 28
3 years 6 months ago #228385
by Elton
Here in the diesel injection business (non CAT) we still occasionally see someone who uses veggie oil as their fuel. It smells good when burning but isn't good for the fuel system. Used veggie oil is particularly bad because of the salts and unfiltered parts of stuff. We have seen more than one injection pump absolutely trashed for this reason. I expect hydraulic systems could suffer a similar fate, but I don't have any experience with that. Elton
D4 hydralic system
Time to create page: 0.199 seconds
