More info on ZENITH Carbuerator for D3400 srarting engine posted earlier
3 years 6 months ago #228229
by novavalleycat
I neglected to say that i have taken the carb. all apart again soaked it in cleaning carb. solution,blew it out with air,put it back together and adjusted,with the same results,a low idle and nothing more
Fat Dan
Thank you received: 240
3 years 6 months ago #228231
by Mike Meyer
I have a carb here it was easy to put to governor linkage tongue on the wrong side of the carb butterfly shaft, stopping it opening up, if that makes sense
Fat Dan
3 years 6 months ago #228237
by novavalleycat
Thank you Mike for your answer,this would make sense if I had any of the butterfly linkage apart but I did not take it apart.
Fat Dan
Thank you received: 6
3 years 6 months ago #228286
by cojhl2
If you had the carb off and apart you can get that linkage Mike is talking about backwards.
My question though is: Does the engine not run well when off idle or will it do nothing other than idle. If the latter grab the linkage and open it. If it wont speed up then that means there is a restriction in the intake air stream after the carb(highly unlikely).
9U(2), 5J, IHC544, Ford860
Fat Dan
Thank you received: 344
3 years 6 months ago #228287
by edb
also be aware that the later carbs with the 90 # linkage at the main jet needle reverses the apparent action of said needle when adjusting the mixture screw---screw the main jet adjuster screw IN to make the mixture Richer and OUT to make the mixture Leaner.
Fat Dan
Time to create page: 0.147 seconds
