955L final drive bearings
PhilC
Hello All
I am replacing the bearings in the left final drive of my 955L and I am having trouble with some of the part numbers. The following part numbers do not come up on parts.cat
Inner race 9S-8669
Outer race and roller assembly 6B-5067
Cup 7B-0357
Does anyone know if these have an interchange part number?
Regards
Phil
Wed, May 5, 2021 5:21 PM
jdwalkbehind
Send a private message to jdwalkbehind
Philc,
Below is what I found.
9S-8669 updates to 6V-1014
6B-5067 updates to 6V-1013
7B-0357 updates to 5D-7449
Wed, May 5, 2021 7:17 PM
PhilC
Reply to jdwalkbehind:
Philc,
Thank you jdwalkbehind
I have found a few other numbers that don't work. Where do you cross reference them? Is there a PDF that can be downloaded?
Sat, May 8, 2021 4:50 AM
Thank you received: 19
Reply to PhilC:
Why not go directly to Manufacturer's numbers.
9S8669 = Bower/BCA # MRB1314
6B5067 = Bower/BCA # M1314EHL
7B0357 = Bower/BCA #67322
Sat, May 8, 2021 6:28 AM
PhilC
Philc,
Thanks OM. Where did you get that cross reference from?
Sorry for the questions but I am not one to expect others to look up numbers I can look up myself if I can be pointed in the right direction. I feel I am asking too much😊
Mon, May 10, 2021 5:51 PM
Reply to PhilC:
PhilC
Check my answer under the D4600 Piston clearance post. Got rushed and plugged in the info on the wrong post.
Mon, May 10, 2021 10:35 PM
