Where to buy Berco chain?
Showing 1 to 10 of 11 results
Thank you received: 61
Hi, I want to buy some new D2 rails for my 5U. I'm in Western NY and would like to know where to buy it. I know there are dealers online but I'm wondering if that's the best option vs. a local dealer whose neck I can wring when they get the order wrong : ) If there is a reputable online dealer, please let me know. The other thing is that my 5U uses 33 link rails vs. older tractors that use 30 links. Would your vendor be familiar enough to know the difference? : )
Related question - do these guys also sell sprocket rings and idlers? I have a set of D3 rollers for it and am contemplating changing the sprocket rings to D3 and would therefore want D3 width idlers.__PRESENT
Mon, Apr 19, 2021 7:11 PM
Thank you received: 255
No answer to your question Neil, but I thought you owned a new set of chains via California way?
Can’t wait to see your D2 completed. JM
Mon, Apr 19, 2021 8:53 PM
Thank you received: 105
Hi, Neil.
https://www.tracksnteeth.com/?utm_campaign=305069818&utm_content=1307319610195851&utm_medium=ppc&utm_term=%2Bberco+%2Btrack+%2Bparts&utm_source=bing&msclkid=c18e4d0e6f471e3c45062d73aea792ec
Just my 0.02. Hope it helps.
Tue, Apr 20, 2021 12:48 AM
Mike Meyer
Hi, Neil.
Neil, those D2 tracks on fleabay in the UK are cheap buying, it shouldn't cost too much to get them shipped to the east coast
Tue, Apr 20, 2021 3:06 AM
Reply to Mike Meyer:
Try the nearest Dressta [IH] Komatsu dealer, they carry Berco.
Tue, Apr 20, 2021 4:43 AM
Very good everyone, thanks for the info. Would anyone know the diameter of D3 idlers? If I go with D3 chain to match my rollers, I'll want at least the right width idler and if a D3 idler is close to a D2 idler (23 inch or thereabouts for the large idler) I could bolt those on. JM, those rails from CA are for the 3J, which does take 30 link chains.
Tue, Apr 20, 2021 7:59 AM
Thank you received: 31
Hi Neil,
hopefully I am smart enough to add this PDF of the Custom Track Service Hand Book, 16th Edition, 2007, Form Number :- PEKP9400-04.
Tue, Apr 20, 2021 9:44 AM
Reply to edb:
Hi Neil,
Worked a treat, thanks Eddie! I see a reference to a D3NC, which has the same inside and outside spreads as the D2 - I'm not familiar with the NC designation - do you know what that refers to? And for the other D3s (original, B, C) it looks like the inside spread is the same as the D2 (2.3😎 and the outside spread is 04 larger at 4.74. Based on that, I would have some "overhang" which I initially thought wouldn't be an issue, but then after some wear set in, a ridge would end up on the rail surfaces and the chain could start running off-center. What do you think? If I could get a hold of the chain that fitted the D3 NC, then it's a perfect fit for existing D2 idlers, but if I go with the D3(original, B, C) chain, then I'd want to upgrade my idlers. I already have a set of D3 rollers so that part's done, and I could continue to use my existing sprocket rims. Thoughts?
Tue, Apr 20, 2021 6:54 PM
Mike Meyer
I think the NC refers to "Non Current", meaning no longer serviced, or it's been upgraded, but I'm usually wrong.......
Wed, Apr 21, 2021 2:52 AM
Neil--just got a quote on a set of rails for my 941b--it was from Tracksnteeth,inc--and the shipping was $175--they sy they have 60 locations in the US that they ship from and one appears to be Canadian Niagara Falls
Thu, Apr 22, 2021 4:11 AM
Reply to dpendzic:
Wow that's pretty good Dan. From Canadian Niagara Falls to my place is probably only 20 clams, it's just down the road. Would you happen to know if I can remove 3 links from the 36 link D3 SALT track and put the master pin in the resulting two ends? My 5U requires 32 links at 6.125 pitch
Thu, Apr 22, 2021 6:41 AM
