what model is my 950 loader
Showing 1 to 10 of 10 results
Yukon950
Send a private message to Yukon950
Hi guys. I am very new to all this, but happy to be a part of the community.
I have a 1968 950 loader, SN 58H515. Photo attached. Can anyone tell me what the model is?
Many thanks!
Sun, Apr 18, 2021 7:14 AM
You've already identified it. A model 950 wheel loader built in 1968 with D330A engine.
Built in Canada same as 90Axxxx US model.
Sun, Apr 18, 2021 8:06 AM
Yukon950
Forgive for not repleying emedeitly.i'm trying to learn computor.i thankyou too much for your knowing of cat equipment=my wife helps me also a good friend with this instrument=I'M greatfull.now i know how to order parts.you have a good one.
Sun, Apr 18, 2021 9:48 AM
Onfoot
Send a private message to Onfoot
Reply to Yukon950:
Well done, Yukon950. And welcome to the ACMOC forum. I know you have a huge amount of experience and wisdom to add to some of the discussions.
Sun, Apr 18, 2021 9:25 PM
Reply to Onfoot:
Hi, Yukon950.
Unless I am mistaken, that would be the "A" series of the 950 loader line - WUNN TUFF MACHINE. I got to operate a couple of them. Have fun.
Sun, Apr 18, 2021 10:32 PM
Thank you received: 14
Reply to Onfoot:
Not sure if what you meant was which of the multiple series of that model it is, but from my untrained eye, it looks like the first series produced in the 950 model range. I'm only saying that based on the cab arrangement. I drove a 950B loading logs in the 80s for a while and yours does not look like the same cab
Yukon950
I want to thank you Neil for your information=I just know enough about this loader to get me in trouble=
Mon, Apr 19, 2021 8:32 AM
Yukon950
Reply to Yukon950:
Neil i should have mention that Magnet told me the loader was a 'a' model loader=thank you both=
Mon, Apr 19, 2021 8:44 AM
Yukon950
Reply to Yukon950:
Good day Gentlemen=The name is Yukon Bob=I own a 1968 950 loader=Problems with the air compressor=removed and checked unloader poppet valves=This compressor has been over worked from a few air leaks=Delivery valves springs are weak and one broken from over heating=Cat compressor I believe it is a Bendex Westinghouse Cat P/N is 9M5475 number TU-FLO 300=I under stand from another Gentleman that a TU-FLO 400 can also be used=I'm in need of a compressor an exchange unit or a rebuild kit=This compressor is a pulley and belt driven=
Sun, Nov 7, 2021 10:52 PM
Reply to Yukon950:
Hi Bob,
if you have no success with your above requests Down Under here at our Cat Dealer we used to purchase some parts from our parts department and also a local on highway truck repair shop that specialized in brake systems.
Mainly we sent the barrels/cylinders or blocks to them for boring out over size and then get them to supply the overhaul kit and oversize pistons and rings to suit.
Hope this helps.
Mon, Nov 8, 2021 5:38 AM
Thank you received: 28
Reply to edb:
Hi Bob,
Hope this helps.
your local engine reconditioner may be able to help you by reboring it to a size and fitting car rings. really no different to engine rings.
as its a bendix wabco unit try any good heavy truck workshop they may be able to supply the parts to fix it. also any good brake shop that does heavy truck work will be able to help you.
Mon, Nov 8, 2021 3:48 PM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
