D2/D4 pony carbs
3 years 7 months ago - 3 years 7 months ago #227240 by hfdzl
D2/D4 pony carbs was created by hfdzl
I recently picked up a box of pony carbs. Sorted thru and found 4 that look OK at first glance, but on a real look the choke and throttle levers are on the wrong side .Wiewed  from the float bowl side. So what are these for? Can't even use on a Cat, the castings are just enough different to swap everything to the other side. They will now just go in the archives. Will post photos in a bit
the 1 with a bowl is Cat.
R2 5E3562 SP U.S.A. W.9151
R2 5E3563 SP U.S.A. W.9152
Last edit: 3 years 7 months ago by hfdzl.
3 years 7 months ago #227241 by Ray54
Replied by Ray54 on topic D2/D4 pony carbs
It has been talked a about using carb gasket kits from John Deere. Some of there late 2 cylinders tractors where diesels and used a pony motor for starting. I have never even looked at one at a show so don't know how much was the same on the carb. Just that a gasket kit was usable on the Cat pony carb. So maybe that is what you have.
3 years 7 months ago - 3 years 7 months ago #227242 by Old Magnet
Replied by Old Magnet on topic D2/D4 pony carbs
John Deere Carb...
Last edit: 3 years 7 months ago by Old Magnet.
The following user(s) said Thank You: hfdzl
3 years 7 months ago #227243 by hfdzl
Replied by hfdzl on topic D2/D4 pony carbs
Thanks OM.
Anybody need these?
3 years 7 months ago #227244 by Scoop
Replied by Scoop on topic D2/D4 pony carbs
Hey there, I'm rebuilding a D6 8U-2042 Pony Motor and could use a bowl for the carb,,, mine has pin holes in the bottom and a lot of pitted corrosion on bottom. I see the fist one is a Zeneth that looks similar to mine. There should be a gold round tag on top of the bowl, carefully clean and you should be able to read the numbers. If it matches what I have I would be interested, thank s Scoop
3 years 7 months ago #227259 by hfdzl
Scoop, the first one is a true Cat carb. Just there for comparison, staying in my parts stash.
3 years 7 months ago #227271 by Scoop
hfdzl, ok if you come across a decent bowl for a Zenith 7M 4048 i could use one, best Scoop
2 years 8 months ago - 2 years 8 months ago #236156 by Dirtbiker1824
Replied by Dirtbiker1824 on topic D2/D4 pony carbs
Whelp my jet assembly separated while taking the carb apart, P/N 5F7640, and I'm looking for another one (or a whole carb/throttle body). I didn't realize it was 2 parts, but the needle was stuck in the throttle body and the threaded section spun out - it's just a heavy press fit between the needle and threaded base. My backup plan is to try and fabricate one using some .093 x .014 wall brass tube. Anyone out here have a carb they're willing to sell? If not I'll buy parts - I also need a new choke plate shaft, P/N 9B4977 I believe. The screws sheared off when trying to remove them after melting the solder, I may not have gotten the backside hot enough. I can try to drill out the fasteners, but it would be easy to just turn a new part if I can't find a replacement.
If anyone has a jet assembly laying around but not wanting to sell, I could really use a dimension check on the dimensions labeled "A", "B", and "C" on the attached PDF.
This browser does not support PDFs. Please download the PDF to view it: Download PDF
Thanks!
Proud owner of a 1942 D4 7U
Last edit: 2 years 8 months ago by Dirtbiker1824.
The following user(s) said Thank You: Fat Dan, Shaban1983
2 years 8 months ago #236159 by rax200
Replied by rax200 on topic D2/D4 pony carbs
I just posted a reply in the wanted / for sale discussion page.
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
2 years 8 months ago #236160 by restore49
Replied by restore49 on topic D2/D4 pony carbs
  That needle is available from John Deere AR13009R. Gasket kit K2067. Bob
The following user(s) said Thank You: Fat Dan, Busso20, Shaban1983
