Spark Plug wire question
Showing 1 to 10 of 11 results
Hey guys, I am getting close to the first start after the restoration of my CAT 22, 2F5209. A real simple question. What plug wires and connectors should I get, and where to get them? Probably as important, what plug wires and materials should I avoid? Most of what I see on line are silicone, or some other fancy material that might not be good for an old CAT.
Tue, Mar 16, 2021 8:35 PM
ag-mike
It has a mag, get whatever you can find/want THAT has solid wire core. Most likely will have mutiple wire strands, okie dokie, fine good to go.
Tue, Mar 16, 2021 10:14 PM
Thank you received: 57
Reply to ag-mike:
Hi Ray, Brillman.com has spark plug wire that is listed specifically for a Twenty-Two for about 30-40 clams but they also sell stock so you can make up your own
Tue, Mar 16, 2021 11:14 PM
Mike Meyer
Thank you received: 6
I second Neil's recommendation, I've used Brillman's cloth wrapped copper core wire and fittings over the years, all good quality, just buy a roll of the vintage style black wire and cut to length.
Wed, Mar 17, 2021 3:15 AM
Reply to Mike Meyer:
Thanks, Guys. I just placed an order with Brillman.
Wed, Mar 17, 2021 3:41 AM
Thank you received: 49
what is harder to get are the metal crimp on plug ends. I tried some very nice aftermarket NGK insulated twist on ends and they wouldn't work. changed to metal ends which took some finding and worked a treat just not insulated so mind your hand when working around the running pilot engine dad found out the hard way and the tilt tray driver thought it was a great joke as he saw the spark bite dad while standing beside the truck. we had just bought her home and were unloading it.
Sun, Mar 21, 2021 8:11 AM
ChuckC
Send a private message to ChuckC
Reply to trainzkid88:
I was able to get all the metal ends and the rubber insulators at my local auto parts store
Sun, Mar 21, 2021 8:24 AM
Reply to ChuckC:
thankfully in the state you have a larger classic and custom car scene than we do in Aus so those sort of things are more readily available. there's more people just in new york city than in my entire state. it doesnt help im in a small town either our local stores dont carry much of that stuff.
Sun, Mar 21, 2021 12:04 PM
d2gary
Thank you received: 45
Just ordered wires from Brillman for my d2 pony motor. Really like the insulation on the spark plug end, have been bit more than once by the raw ends
Tue, Mar 23, 2021 10:02 AM
I got the "Modern" sparkplug wire set, with the molded insulators. Excellent quality. [img]https://brillman.com/wp-content/uploads/2018/08/B1008-003M-1-web.jpg[/img]
Tue, Mar 23, 2021 7:59 PM
Fat Dan
[quote="[email protected]" post=226721"]Hey guys, I am getting close to the first start after the restoration of my CAT 22, 2F5209. A real simple question. What plug wires and connectors should I get, and where to get them? Probably as important, what plug wires and materials should I avoid? Most of what I see on line are silicone, or some other fancy material that might not be good for an old CAT
.https://youtu.be/r61xQ_rf1wo CAT 22 SOLD
 [/quote]
Sun, Mar 28, 2021 7:20 AM
