Are these lamps OEM?
Delta KJ
I have a verly late model D2 (5U17xxx) with an original 24 volt direct start system.  These are photographs of the 24v lamps that were on the tractor when I bought it.  They don't look like the lamps in the parts catalog and I can't find any identifying numbers.  Are these lamps aftermarket lamps or Cat OEM?
 [attachment=62401]Lamp1.jpg[/attachment] [attachment=62402]Lamp2.jpg[/attachment]
Thu, Mar 4, 2021 11:14 PM
Yes Cat! late 50's tractors used those. 5H2067 Head Lamp with 1M5898 sealed bulb.
Thu, Mar 4, 2021 11:39 PM
Delta KJ
Thanks Rome; that infomation is helpful because I'm trying to keep the tractor as "period correct" as possible.
Kevin
Fri, Mar 5, 2021 7:10 AM
Reply to Delta KJ:
Kevin
Your welcome. You can put halogen bulbs in those too for a brighter white light, part # 9W-1281 or ANSI # H4578
Fri, Mar 5, 2021 10:15 AM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
