D4 #7J fuel injector torque specs??
1941D4DOZERBOY
Send a private message to 1941D4DOZERBOY
can anyone tell me the fuel injector torque specs for the 4 1/4 bore engine 7J D4 ?? also what is the torque procecedure to tighten them down?
Wed, Feb 10, 2021 8:50 AM
I would use standard grade five bolt torque, tighten each side evenly. I'm not aware of anywhere Cat speced a torque for those.
Wed, Feb 10, 2021 10:12 PM
Thank you received: 19
I have not seen a torque spec. What info I have states to tighten enough to where there is no leakage. Over tightening can lead to distorting the injector.
Thu, Feb 11, 2021 1:02 AM
With the later style fuel nozzle capsules, like on the D311, D315 engines is where you have to be careful not to over tighten, those are hand tightened to the adapter and the nut is torqued to 105 ft lbs.
Like mag mentioned tight enough so there is no leakage.
Thu, Feb 11, 2021 2:19 AM
