D6 8U Pony Motor Rebuild Discussion
3 years 10 months ago - 3 years 10 months ago #225234 by Scoop
Good Evening,
New to forum and may be a little clumsy here so please bear with me.
Gotta D6 8U-2042 Dozer been working on for a few years. Struggle to keep Pony running to fire up main engine. Been able to tweak just enough but kept getting worse. Finally decided to pull and tear down. Found Exhaust valves not seating good and lot of carbon buildup, intake valve with broken spring, rings worn (comp @ 0.065" gap), little pitting on one rod journal, main journals look good, main aluminum bearings scored a little bit, bottom water ports on heads clogged with heavy gunk, crank rod and main journals within tolerance as I measure, cylinders and pistons look good no scouring.
Plan is to have looked at this weekend by an old timer machine shop near me to make sure it is serviceable and then rebuild. Would like to keep an active feed going through the rebuild to let you know how it's going and to have some guidance.
Here's my problem right now, I'm a little uncertain about calling out the right part numbers. I see some great contacts in the Library, but before reaching out to them I'd like to bounce the problem off you guys to see if you can help.
I have the shop and parts manual that is spot on for the Crawler. The parts diagrams for the Pony look darn near perfect (minus one filter element on manifold assembly head for all 8U models, idk why), EXCEPT some of the major part numbers in the Manual/Book are slightly different than the ones stamped on the parts.
Here are the differences on Major Parts:
Manual/Book No. on Part
BLOCK ASSEMBLY IF3529 4F8395
COVER ASSEMBLY (REAR) 4F2204 4F2003
MANIFOLD ASSEMBLY 5F8254 5F8253
HEADS 4B2459 4B2458
GEAR (TIMING) 4B2330 4B2329
FLYWHEEL 5F8407 5F8406
ROD ASSEMBLY 7B4613 7B4612
Most numbers above are close with only a one digit difference, except for the Block and Rear Cover Assemblies, hmmm. So, not sure if this matters much when I order parts. Never ordered for the Pony and figured I would just have to call out the 8U-2042 number. The only other number I see is a stamped plate on the Magneto - MJK 4/2 360-B-410 with S/N 3A 83375. Other than that I don't see anything else unless I'm missin something?
Any help on this is appreciated!!
Scoop from Forestburgh
Last edit: 3 years 10 months ago by Scoop.
3 years 10 months ago - 3 years 10 months ago #225241 by Old Magnet
The numbers you are reading off the parts are actually casting numbers in a lot of cases. You need to go by the parts numbers in the parts book for ordering parts. The difference in numbers between casting and parts usually, but not always, reflect the number of machining operations done to the casting. So if there are no machining operations the casting and part number will be the same. There are always exceptions but that's the general explanation of why casting and part number don't match.
The small filter you refer to is actually connected to the intake runners in the top cover. There is a small hole, about 0.050" diameter that serves as a drain for raw gas that might be discharged from the carburetor. This hole is almost always found to be plugged. Nice to have it functional but not a show stopper.
Last edit: 3 years 10 months ago by Old Magnet.
3 years 10 months ago #225267 by Scoop
Thank you Old Magnet, can’t tell you how much better that makes me feel knowing a number difference is normal. No sign Pony was ever replaced so I’ll play it straight and stick with part numbers for the 8U-2042 model I have. Will post pics of the rebuild along the way and certain to have more questions! On to the machine shop tomorrow!
3 years 10 months ago - 3 years 10 months ago #225296 by Scoop
Ok, today was a bit of a setback. Unfortunately the bore press at Steve's Machine Shop in Liberty NY came up just a little short on the 22-3/8" wide block. He recommended a couple of nearby shops to consider and I'll check them out on Monday. Said he's been in business over 40 years working on all kind of equipment back to the 20's including heavy machinery and has never got stumped like that. He looked the Pony over and said he would just polish its crank (not cut) and replace the main and crank bearings and that it was time to bore the cylinder, replace the pistons, valves, springs and bushing guides (didn't ask about the connecting rods, thoughts?). My measurements show the cylinders have worn from a Std. Bore of 3.126-3.127" to 3.1368" ( 0.0103" oversize wear), Pistons Skirts worn from Std. 3.120-3.121" to 3.1162" (-.0043" wear) and Piston Lands from Std. 3.106-3.107" to 3.1018" (-0.0047" wear). The compression ring gap when inserted into the bore was 0.065" and should be 0.012-0.022". Animal cruelty!So, the plan is to locate a shop and continue the journey. I'm going to post a bunch of pics her of the tear down to show a few things and ask some questions. New to the forum I'm not sure what the policy might be for posting too much. I ran a test and saw that there is a limit for each reply so I'll do it in a couple of parts.
Block (Top)
Block (Front)
Block (Back)
Block (Right) - Water ports on lower right is clogged
Block (Left) - Water ports on lower left clogged
Heads (L,R) - Water ports clogged on lower portion. Machine has been sitting for 18 years with me now and never put to work. Would start regularly until Pony was too difficult to keep running 3 years ago. Machine has remained in a Garage in a Box for last 8-10 years waiting for a Pony rescue. Undercarriage and main engine and other essentials all work good. When running the Pony I would always have to drain coolant out of the heads, one side more than the other can't remember which.
Top Cover - If you look close on right side you will see a hole eaten through the cover where the Starter bracket goes.
Here it is a little closer. Next photo will reveal why ... I think.
Bottom side of Top Cover - Defect in casting showing a "Polyp" of iron that didn't make it to where it should have.
Top Cover Underside
Crankshaft
Crankshaft - Timing Gear Side
Crankshaft - Flywheel Side
Last edit: 3 years 10 months ago by Scoop. Reason: running test for posting pics
3 years 10 months ago #225298 by Scoop
More pics on teardown:
Main Journal - Timing Gear Side; Spec is 1.9995-2.000" with 0.005" out of round. Looks good (I think).
Main Journal - Flywheel Side Ok
Left Connecting Rod Journal; Spec is 1.8745-1.8750" with 0.003" out of round. Ok
Right Connecting Rod Journal - Ok
Main Bearing - Flywheel Side; Some scoring, Replace
Main Bearing - Timing Gear Side; Some scoring but not as bad as TG side; Replace
Connecting Rod Bearing - Left Piston; Scoring; replace
Connecting Rod Bearing - Right Piston; Scoring; replace
Left Piston and Valve Assembly - Best of 4 valves was the Intake shown here, looks new but is only one with a broken spring!
Right Piston and Valve Assembly
Pistons, Valve Assemblies and Camshaft; Pistons measure wear but do not appear to be severely scorn ...??? Triple checked measurements with difference between cylinder wall and piston skirt of 0.0206" vs 0.006" spec new and piston lands of 0.0350" vs 0.020" spec new.
Exhaust Pipe, Flange, and Block; Question - any thoughts on exhaust pipe replacement (2 parts). The parts are discontinued from CAT and expect it will be hard to find and if I find it may be expensive. Plan to ask around but wonder if I shouldn't have made up or idk..
Water Pump; Here's another one. The pulley is worn down to the size of a potato chip on the left. Part is discontinued. Not sure what makes the most sense here, look for it and grab it or can it be built back up??
Starter, Starter Pinion, Magneto and Governor; Last of the teardown parts. If you look at the end of the Starter Pinion you'll see a missing dog ear. Engaging the dozer was a circus ... would have to hold the pinion in from popping out while trying to keep the Pony going and hitting the fuel. Funny but not! Remember seeing the missing dog ear inside the dozer flywheel housing, TG!! CAT wants $282 just for one ear!!! I'm diving back in to find it! lol
Any feedback is appreciated, thank you.
3 years 10 months ago #225301 by Cat Yellow1
Scoop - you might be able to find some of those obsolete parts at Florin Tractor. I purchased a pair of pinion latches last year for my D2 much cheaper than Cat wanted.
The following user(s) said Thank You: Scoop
3 years 10 months ago #225315 by neil
If for some reason you're unable to find the exhaust manifold, a custom exhaust shop will be able to make that up no problem. I used to do a lot of replacements like that, substituting either mild or stainless for the cast tube. Cut the flanges off and reuse.
3 years 10 months ago #225352 by Scoop
Any suggestions on how to remove head studs without breaking them? Found a machine shop in Port Jervis NY with press large enough to do the job. He’s a one man band and swamped so it’s going to take some time. Suggested I remove the head studs myself and said to be careful if they break it’s going to run into a lot of time and money for him to remove. Said not to heat which is contrary to anything I’ve ever done but I’m nonprofessional just a jack of all trades. Also said to tap block and end of stud with nuts on and take it slow.
3 years 10 months ago #225368 by Scoop
Got em all out old school 👍
3 years 10 months ago #225385 by Bmr
I have a NOS exhaust manifold here if needed
Calls are best 507 402 2720
Thanks Jon
Time to create page: 0.245 seconds
