That's similar to the approach used in the past for the D2 master pin. Cat went away from that presumably because it wasn't as effective as a straight, interference-fit pin. Could have been due to cost but I doubt it, given how simple the plug and pin components were. If you're regularly exchanging buckets, it would be helpful. I know that it's quick and easy to split my D2's tracks with this system, but I haven't driven it long enough to see how long it stays locked.
My Machine is Cws lugs for bucket changes but the pin at the end.of the stick that the thumb pivots on as well the bushings or pin boss are worn out near excessively
