3204 / 3208 injector removal
Showing 1 to 6 of 6 results
Steve A
How do I remove the injectors from this 3204 cylinder head, I have removed the hold downs. Is there a Tool of choice ?
[attachment=61792]IMG_5013.jpg[/attachment]
Sun, Jan 10, 2021 4:49 AM
there is a special tool for the pencil injectors, maybe try Google--before it became available we used 2 suitable pry bars very carefully and with equal force trying not to bend the injector stem--if bent they may not be accepted as an exchange core--and may not work as designed if refitted--a test on an injector pop tester may or may not tell.
To clean the nozzle tips we used to hang the tips in an ultra-sonic bath to clean any carbon from the cavity within the tip and/or the orifices. Piano wires of a suitable size can be used in a pin chuck to prick out the orifices too.
Sun, Jan 10, 2021 6:20 AM
Reply to edb:
The puller group for the 3204 is a 6V6976 but I don't think you can get it individually any more.
It is now part of the 6V7020 nozzle puller group that fits several engines. You will not like the price.
Sun, Jan 10, 2021 7:30 AM
TractorDanD2
Send a private message to TractorDanD2
I always used 2 small J bars. Just take it slow and use them to pry up the injectors. Cat has a tool that looks like a fork that will fit in under the nozzle housing were the lock is located., but its not cheap. Never had 3204 or 08 nozzle that I couldn't get with the J bars. As for the nozzles in the 3304 DI engines, I cut the line nut of and old line and welded a nut to it to be able to use a slide puller. Also, I would suggest that you never lay the heads down on a flat surface until the nozzles are removed. Protruding nozzle tips can be easily damaged. Good Luck with it!
Mon, Jan 11, 2021 9:18 AM
Steve A
Reply to TractorDanD2:
I managed to get the first one out using 2 pry bars, I am hoping I didn't damage it, it was not easy, I decided to have a shop with a proper puller remove the other 3. I did lay down a sheet of cardboard on the work bench to cushion the tips and soak up the dripping gunk.
Tue, Jan 12, 2021 8:36 AM
TractorDanD2
Reply to Steve A:
Sometimes removing nozzles is a hassle. Hopefully all will be ok and not too expensive.
Tue, Jan 12, 2021 5:41 PM
Steve A
after work today I decided to put more effort into the 3 remaining nozzles, after a bit of study I decided to use a set or curved jaw vice grips lightly clapped around the top to form a better collar to work against with the prybars. With this arrangement the last 3 came out with ease.
Wed, Jan 13, 2021 6:43 AM
| Hartley - South Australia
Newby Hall Tractor Fest
