no oil pressure on D-4
Showing 1 to 10 of 11 results
vailvalley59
Send a private message to vailvalley59
Please help with my current problem. I have a D-4 Serial 5T that has been a good machine for me. It has not run for several years. When I started it up several days ago I had no oil pressure in the Cat engine. The oil is full but dirty and 30 weight. What can I do to prime the oil pump if that is possible? Have not had a problem in the past like this--any ideas are welcome. Thanks
Tue, Dec 29, 2020 12:29 AM
gary in CA
First thing I would do is make sure the guage is working
Tue, Dec 29, 2020 1:25 AM
Reply to gary in CA:
as Gary suggests above, first thing is to try another gauge--if you do not have another gauge disconnect the gauge line at the oil manifold and see if oil issues when cranking with the pony engine.
I know of a D4U series that sheared the drive pin at the oil pump drive gear driven by the camshaft (looking in parts books it seems both series engines use the same 0L1027 Pin in the oil pump drive)--this was down in Antarctica back in the day.
If you had water from condensation or such in the oil pan then ice in the pump could cause this or else it could be just the 30 weight oil in freezing weather not pumping also, or ice formed in the suction screen could block it off and stop the pump sucking oil.
Tue, Dec 29, 2020 6:12 AM
Thank you received: 33
Reply to edb:
try a different gauge. remember the gauges on these old girls are more of an idiot light than a proper pressure gauge. so if you use a proper graduated gauge don't expect high readings they only had low pressure high volume pumps.
Tue, Dec 29, 2020 6:54 PM
vailvalley59
Thanks for the replies--today I plan to pump some oil into the line connection that goes to the head on the oil manifold and see if I can get the pump to prime. This should also register on the gauge. Would there be any way to draw the old oil out from the top? I can't get to the drain with the tractor where it is now. I have the means to vacuum out the oil if there is any way to do so. Keep the comments coming-I need to get the dozer going soon. Keith
Wed, Dec 30, 2020 8:18 PM
vailvalley59
Reply to vailvalley59:
This afternoon I was able to get oil pressure on D4 Cat motor--added some lighter oil to crankcase with old oil and primed the oil pump with old grease gun and 15-40 oil. Temperature here today is in the high 40's- much warmer than it has been of late. Still need to get fuel to injectors for engine to run. Good progress so far. Thanks to all Keith
Thu, Dec 31, 2020 4:52 AM
kracked1
Sounds like an oil change needs to be first on the list.
Thu, Dec 31, 2020 5:58 AM
Reply to kracked1:
Hi Keith,
I purchased a down the dipstick tube oil change pump kit from a auto speed shop when I got quoted $40040 to change the oil and filters on my 2004 Nissan Patrol with 4.2 TDI diesel engine towing our 21 ft. caravan/trailer into a howling head wind when I was some 2100 miles from home and needed a scheduled oil change. Final cost was some $100--- $60 for the pump kit plus oil.
Cost $20 donation to service truck that did my mates Mitsubishi--$220 for the Pajero oil change--to take my 10 liters of old black oil.
Be well aware that the oil needs to be warm for these little pumps to work. Maybe put a heater under the belly plate, if fitted, to warm the oil-- BE AWARE of sticks, leaves and oil soaked dirt etc. in the belly plate that could ignite and destroy your machine and shed etc.
Thu, Dec 31, 2020 6:34 AM
TomTrack44
Send a private message to TomTrack44
Reply to edb:
Hi Keith,
Keep working at it. My 5T has a rod thru the block on the pony, the rest of the tractor is in pretty good shape, may even get around to replacing the pony in 2021.
Thu, Dec 31, 2020 9:25 AM
vailvalley59
Reply to TomTrack44:
Got everything going now--fuel rack was stuck in off position--PB blaster did the job. Installed a new to me, used exhaust manifold today-went better than I expected--those brass nuts did the job. Thanks Keith
Tue, Jan 5, 2021 6:27 AM
D4Jim
Thank you received: 12
Reply to edb:
Hi Keith,
[quote="edb" post=224842]Hi Keith,
Eddie B.[/quote]
Eddie, those little dipstick suckers can come in pretty handy. We use them on our 4 wheelers to change oil and saves a lot of time as we change oil so often in them. The newer ones (4 wheelers) have so much plastic and crap under them that make finding the drain a headache!!
Cats Forever
Tue, Jan 5, 2021 9:34 AM
