Cat D2 5U series
Cat D2 5U series
Thank you received: 5
3 years 4 months ago #223827
by Bluegrass1985
Does anyone know where I can buy oil and water temperature replacement gauges. Want mechanical but does not need to be original style. Just something that works.
Thanks Don
Thank you received: 280
3 years 4 months ago #223829
by Ray54
Most any auto parts store should be able to help. My biggest problem with generic water temperature gauges is the capillary tube is much longer than needed and it needs to tucked up out of the way. I preferer products from USA companies but may not be possible today. Over 20 years ago had a Stewart- Warner (which I thought was a good brand) temp gauge that stopped at about 200 degrees worked fine in the normal range. That ended up costing a little but no serious damages done. So it always pays to double check if you thing the gauge could be off.
Know what size face you now have and buy the right plumbing to connect from the block to oil psi gauge. It has been discussed before but I think Cat oil psi has 10 to 30 psi in the normal range on the older models. Hopefully someone will confirm or give better information on that.
Thank you received: 74
3 years 4 months ago - 3 years 4 months ago #223833
by dpendzic
Cat sells a bezel for the newer gauges that makes it look like the old style gauges
On ebay for $25
5M1065 GAUGE - OIL PRESSURE for CaterpillarĀ® (1W0705, 1P5487)
D2, D3, D4, D6, 941B, Cat 15
Hancock Ma and Moriches NY
Last edit: 3 years 4 months ago by
dpendzic.
Cat D2 5U series
Time to create page: 0.122 seconds
