D4 pony drive questions.
Showing 1 to 10 of 59 results
Mangoman
Send a private message to Mangoman
I'm looking to do a swap or make two into one good using the pony drive from my 5T and 7U. After watching Toby's video regarding his 5J, he says that both J series and later U series are the same minus the curved handle and so I am hoping the same for the D4 which I believe is the same starting motor. The question I have is what all needs to be removed in order to remove the drive? In the Serviceman's Manual they make it sound like all you need to do is block up the pony and it will slide right out. The fuel pump seems to be an obstacle. Hoping the whole machine wasnt built around the pony drive...
Sat, Nov 21, 2020 12:20 PM
D4Jim
Thank you received: 10
Cat manuals are known for over simplifying an operation. Maybe it is the white lab coats that help them.
I am not sure about the 5J but I have a D47U (1950) and the pinion, clutch etc will come out if you have the pony raised high enough to clear the pinion gear.They say two inches but I lay 2x4's on edge to raise the pony about 3-1/2 inches. You have to remove the back governor case cover and the cover on the front of the clutch brake. Getting the whole mess out of the housing can be a chore as they get rusted in and need a lot of Kroil and gentle tapping to get them loose. Don't beat them too hard because they can break. As for the 5J I have never worked on one so don't know if there is any difference. It is a big help if the pinion can be latched to shorten it up. It is a tight fit but it will come out on the 7U. .
Good luck.
Cats Forever
Sat, Nov 21, 2020 1:24 PM
Cat Yellow1
Send a private message to Cat Yellow1
Reply to D4Jim:
Good luck.
I just removed mine from a D2 and the first challenge was overcoming the force of the large o-ring in the rear of the pinion. It's a pretty tight seal and not easy to grab to pull or pry to break the seal. I was careful not to put too much force around the area where the bolt holes are, in fear of breaking the corners off. After I got that free, there wasn't much room between the governor and the pinion, I had to give it a little pry to get it to clear. It took me a while but I finally got it.
Sat, Nov 21, 2020 6:14 PM
Thank you received: 19
Reply to Cat Yellow1:
The 3/5J comes out with no additional disassembly from my recollection. The 4/5U series though required the governor and pinion covers both to be removed. But the tightness issue with the o-ring is the same on both series. I did get an updated o-ring number where the cross-section is just a little thinner and so the fit was a bit easier.
Sat, Nov 21, 2020 8:53 PM
d2gary
I can't remember right off hand if the d4 and the d2 are the same but there is a bolt in the inspection cover on the side of the block that has to come out in order to remove the mounting bolts on the underside of the clutch housing. Its pretty obvious after a few cuss words but thought I'd let you know.
Sun, Nov 22, 2020 12:25 AM
Mangoman
Thank you everyone for the input. Am I missing something? Seems like the whole governor assembly needs to come off. I was hoping things would be minimal. I still have quite a long way to go for the nose of the drive to clear.
Sun, Nov 22, 2020 12:36 AM
Deebo
Librarian
Thank you received: 30
Reply to Mangoman:
I took the whole governor off on my D4 2T, made it straightfroward. As Neil said overcoming the large o ring takes a some force. I actually used a little heat to soften the o ring which helped a lot.
Sun, Nov 22, 2020 3:09 AM
Reply to Deebo:
Is the pinion latched to make it as short as possible?
Sun, Nov 22, 2020 5:55 AM
Cat Yellow1
This is where I pried from the back. The top of the pinion and the bottom of the governor were making contact, so I took a pry bar and gave it a little help. Didn't take much. Like Neil mentioned, I had the pinion engaged.
Sun, Nov 22, 2020 7:17 AM
Mangoman
Thanks for the pointers everyone. I'm a little unnerved at the thought of removing the governor assembly. I'm doing this right out in the open. In the muck in the corner of our yard. It's what I've got! I was hoping to have it sorted before we get a dump of snow.
Today, I drained the coolant out of the 5T, removed the dash panel, linkages and unbolted the pony in preparation for lifting it. The pony exhaust bolts were pretty seized on the main eng intake side. I've got them covered in a rag soaked with liquid wrench so hopefully after a couple days it will be more easily persuaded. I don't have a oxy acetylene setup so taking the slow road. That was enough for me today. I don't work on my tractors unless I feel like it. I only do this for enjoyment 😁
I believe the pinion is latched on my 7U but I will double check. Also, it the spirit of saving money I seldom go to the Cat dealer but I'm thinking I will for the large o ring for the drive to the housing. Is cork gasket a valid material for between the pony block and the bellhousing? Its 1/16". Or should I only use paper type? I have the cork in a large chunk so that is why I ask.
Much thanks!
Sun, Nov 22, 2020 10:40 AM
Mike Meyer
Reply to Mangoman:
Much thanks!
Nathan, according to the Cat parts website that pinion O ring, 2A3676 is 0.28" thick, and inside dia is 3.35", any hydraulic or bearing shop should have something, Cat price here in Oz is around $US8
Mon, Nov 23, 2020 3:16 AM
| Hartley - South Australia
Newby Hall Tractor Fest
