D2 Pony Backfiring
D2 Pony Backfiring
Showing 1 to 10 of 24 results
Cat Yellow1
Send a private message to Cat Yellow1
Thank you received: 6
Long story short, I rebuilt the pony on the D2 (4U1826) and when I reinstalled onto the diesel engine, fired up fine but was overheating. Pulled it back out and tore it back down to make sure all of the ports were clear. I suspect the problem may have been air trapped in the manifold because I didn't find any blockages. Reassembled (all new gaskets) and reinstalled last week. When I tried to start, wouldn't even pop. Swapped plugs on the coil just to check and still nothing. Pulled #1 plug and plugged it into the wire and laid on the fender and cranked and had spark. Opened the bleeder valves for both cylinders and had fuel come out of both. I was certain the timing was correct, and I had photographed the gears before reinstalling the cover, so I double checked the photos and confirmed the gear was on the crank properly and the camshaft and crankshaft "C"s were lined up. Double checked mag and that was lined up also, so timing looks good. Double checked the points gap and it was about .015 - .016. This is an American Bosch mag and I believe specs for that are between .014 and .018. Opened up the bleeder valve on #1 cylinder and cranked and it blew fire out of it. Had my wife crank it while I was on the right side and heard backfiring in the pony air cleaner. Pulled the pony and diesel intakes and cranked, and had good pressure coming from both exhaust ports and occasional backfire through carb, a couple of times with impressive flames. What am I missing?
Wed, Nov 18, 2020 7:54 AM
D4Jim
Thank you received: 16
Plug wires maybe switched???
Cats Forever
Wed, Nov 18, 2020 9:23 AM
Thank you received: 63
Reply to D4Jim:
Bruce, take #1 cylinder head off, and wind it over to TDC. One one rotation at TDC, both valves should be closed. On the next rotation, they should be "rocking" - exhaust closing and intake opening - somewhere near TDC - I'll pull the head off my pony and check where it happens tomorrow so you can compare. If that looks good, then the problem is your ignition timing.
After it started ok but overheated, did you remove/reinstall the camshaft? If not, then the cam timing should have been unchanged since it started-but-overheated.
Wed, Nov 18, 2020 10:05 AM
Cat Yellow1
Jim - I did swap the plug wires and no change.
Neil - I was thinking about removing the plug and putting air in the chamber at TDC to see if I could hear air coming through the carb. I did remove the camshaft, but I've checked the timing and everything looks correct (see photos below).
[attachment=61104]IMG_4438.JPG[/attachment] [attachment=61105]IMG_4446.JPG[/attachment] [attachment=61106]IMG_4500.JPG[/attachment] [attachment=61108]IMG_4447.JPG[/attachment] [attachment=61110]IMG_4448.JPG[/attachment] [attachment=61107]IMG_4449.JPG[/attachment] [attachment=61109]IMG_4450.JPG[/attachment]
Wed, Nov 18, 2020 5:31 PM
Confirmed that valves rock over TDC. If yours do that, then the camshaft is more or less timed correctly. With the #1 head removed, check that the spark occurs around TDC with both valves closed for that cylinder. Then remove #2 head and check the spark timing there too. Have you confirmed that the exhaust manifold is not blocked? You can remove it, run the leaf blower through each branch of it, and also through the exhaust tube that runs through the diesel manifold. Any blockage in there will prevent it from running.
In theory, if the markings are correctly aligned, then the timing "should" be correct. But the way to know for sure is to check that the events sequence correctly, regardless of what the markings show.
Wed, Nov 18, 2020 9:52 PM
D4Jim
The pony did run OK but it was overheating? In correcting the overheating problem, the timing problem occurred? Doing what Neil suggested should isolate the problem but it sounds like maybe the timing between the cam and the crank is off 180 degrees, Why would I suggest that except been there done that. 😊 The crank can be rotated 360 degrees and the marks will still line up with the cam gear. But if the pony was running beforehand and the crank gear and cam gear were not disturbed, that could not be the problem. The pony will get hot if the main is not turning as the only water circulation in the pony is from the water pump on the main.
Bruce you will undoubtedly be the pony expert after your pony rebuild. 😊
Cats Forever
Thu, Nov 19, 2020 12:55 AM
kittyman1
Reply to D4Jim:
[quote="D4Jim" post=223744]The pony did run OK but it was overheating? In correcting the overheating problem, the timing problem occurred? Doing what Neil suggested should isolate the problem but it sounds like maybe the timing between the cam and the crank is off 180 degrees, Why would I suggest that except been there done that. 😊 The crank can be rotated 360 degrees and the marks will still line up with the cam gear. But if the pony was running beforehand and the crank gear and cam gear were not disturbed, that could not be the problem. The pony will get hot if the main is not turning as the only water circulation in the pony is from the water pump on the main.
Bruce you will undoubtedly be the pony expert after your pony rebuild. 😊[/quote]
if this engine is a twin cylinder....if camshaft (or crankshaft) is out 360 degrees, wouldn't that just swap the firing order?
-overheating...not enough coolant circulation, improper spark timing(usually late), carb too lean of mixture...exhaust restriction...maybe more possibilities...
Thu, Nov 19, 2020 2:54 AM
Reply to kittyman1:
If either shaft is 360 degrees out, then it's effectively unchanged because it will be the same position relative to the other shaft. Where it goes wrong is if it's anything other than zero or 360 degress (which are effectively the same thing). The same goes for the cam to mag relationship however with the mag, it can be 180 out from the cam, if the plug wires are swapped. With Bruce's overheating, it's too rapid to be just a lack of turning the main over. It's burning paint within just a minute or so. Furthermore, when he does turn the main over, it still overheats.
I'd really like to get my hands on this engine and mount it on my test stand and give it a full going-over. As much as Bruce is making his checks and our recommendations, it sometimes helps to have a second pair of eyes and particularly hands on the subject. If a local member could swing by and spend a couple of hours, it could be well worth it.
Thu, Nov 19, 2020 4:03 AM
kittyman1
-the title of the thread is pony backfiring... i assume that's back thru the intake and carb? 90+% of the time...that is too lean of fuel mixture...too lean also creates a very hot burning mixture, raising cylinder temperatures...another red flag....
-double check you are getting plenty of clean fuel (filtered) to the carb inlet...and no obstructions thru needle and seat....and proper float level...
-can you post a picture of the spark plugs....the current plugs you are using?
Thu, Nov 19, 2020 4:42 AM
Cat Yellow1
Thanks to everyone for your replies. I did record an attempt to start with the exhaust and intake tubes removed, and just posted it to YouTube at this link - https://www.youtube.com/watch?v=pVkMyBIytEw It shows a couple of backfires but there were a couple with pretty good flames before I did the video.
Neil - Thanks for checking on the sequence on your tractor. I hope to be able to check that sometime this weekend.
Jim - I did pull the crank and camshafts out. I was concerned about the clearance between one of the cylinder walls and rod, and wanted to file the edge of the cylinder wall down a little. I'm certainly getting very familiar with this pony, but you guys are the experts.
Kittylover - I pulled the cover from the bowl on the carb and it had fuel up to the jet, and moving the float allowed fuel to flow and stop. Also poured a capful of gas down the carb throat and nothing. Last time I installed it, had a similar problem and it fired when I did this. Found the problem to be mud daubers clogged up the fuel inlet to the carb. I did rebuild the carb over the winter, so it's entirely possible it could be out of adjustment, but it ran fine about a month ago. I'm using Autolite 3116 plugs. Photos are below.
[attachment=61121]IMG_4287.JPG[/attachment] [attachment=61122]IMG_4282.JPG[/attachment]
Thu, Nov 19, 2020 7:43 AM
Thank you received: 34
a too lean of a fuel mixture can be caused by the right angle tin lever in the carby main jet system--this causes a requirement of needing choke to run at full speed and load.
The lever gets bent when too much force is used in the initial setting of the main jet for a first run approximate jet opening.
Be aware that this lever reverses the actions of the main jet mixture screw--in for richer --out for leaner.
Because of the flimsiness of said lever it is very difficult to discern when the main jet screw tops out the main jet at its fully raised opened position--miss the subtle change in screw torque to turn it will result in bending the lever beyond the 90 degrees it should be when in service--this then does not open the main jet sufficiently to get anywhere near enough a correct rich mixture for the engine to run effectively with power and not overheat.
Pictures below should explain clearer than I.
Hope this helps.
Thu, Nov 19, 2020 7:50 AM
