thanks for the great info I was looking at it again today and I am sure the motor was changed as the numbers don't match so I better check their ailment too. yes, it will be getting a new throwout bearing and renew all the pins and bushing in the clutch linkage before going back together.
I hate to ask but can someone give me part numbers for the clutch links and throw out bearing. They have 9B399 on the clutch link but that’s not working . Other interesting things the bearing rollers have a grove cut in for grease? Never seen that before. Not having luck finding a parts book right now thanks for any help. [attachment=61282]081B5D32-4BE1-4E2B-8E64-C76631E6DEEA.jpeg[/attachment] [attachment=61284]4AC66B7D-0737-4833-A694-3E5A1A5EEB21.jpeg[/attachment]![]()
I don't have a parts book for the 9U so I can't look up the bearing number. I do have a book for the 5R which I think has the same clutch. Are you looking for the bearing you show in the picture or the bush in the throw out collar?
The 9b399 is a good number for the link and the bearing assambly is 1b4369
Well, I got my new clutch link in today and much to my surprise it was a rubber/fiber link, not plastic like what I took out. They’re only 3/8 of an ounce or 10 grams different in weight. So my plan is to mix them 4 plastic and one rubber one as they are 125 each and well money’s doesn’t grow on trees. I almost made one my self as we have thick plastic at work maybe I still should? Thanks for the help and input. [attachment=61399]87A9C9DD-E848-49E0-B5BE-263EA84D3546.jpeg[/attachment] [attachment=61401]image.jpg[/attachment]![]()
