7F-9084 oil pressure gauge on a D4400?
Showing 1 to 10 of 14 results
Deebo
Librarian
Thank you received: 26
Dumb question, I know that CAT produced the above gauge to give a more sensitive scale for oil pressure range on the D315, I know there was a service bulletin out about it. So I thought I'd be clever and put one on my D4400 powered 2T. But having read in the Servicemen's Reference Book that the operating pressure for the D4400 should be 30 pounds, I'm now thinking maybe this gauge won't be suitable? Anybody used this gauge on a D4400? And if it's the wrong gauge what should I be looking for instead?
Regards,
Tony
Fri, Oct 23, 2020 8:24 AM
Hi Deebo,
Cat literature below on the gauge scale readings---hope this helps.
Cat gauges read maximum pressure reading at the pressure indicated and are so designed to not be damaged at reasonable cold oil excess pressure readings above the maximum indicated.
Fri, Oct 23, 2020 10:56 AM
rax200
Reply to edb:
Hi Deebo,
Hi Deebo,
The updated part for D4 2T oil gauge is 1W5353 the old part no is 8B2355.
Regards
Fri, Oct 23, 2020 4:31 PM
Deebo
Librarian
Reply to rax200:
Hi Deebo,
Regards
Ok, thanks for the info guys.
Tony
Fri, Oct 23, 2020 6:34 PM
Mike Meyer
Reply to Deebo:
Tony
Hi Daryl, do you have a photo of that 1W5353 oil gauge, I'm curious to see what the face looks like.
Mike
Sat, Oct 24, 2020 2:53 AM
bruce oz
Reply to Mike Meyer:
Mike
https://www.agkits.com/caterpillar-oil-pressure-gauge-1w5353.aspx#.X5NQXkfivIU
or 30psi
https://www.agkits.com/caterpillar-engine-oil-pressure-gauge-1w0705.aspx#.X5NQw0fivIU
Sat, Oct 24, 2020 4:51 AM
Deebo
Librarian
Reply to bruce oz:
or 30psi
So reading that bulletin from Eddie it says in there about operating pressure being 30psi for those engines too so that makes me think the 7F-9084 will work for the D4400 too. And Handy on startup as it’s more sensitive or am i missing something as usual?
Sat, Oct 24, 2020 5:01 AM
Mike Meyer
Reply to Deebo:
Thanks for the links BruceOz, the only negative with those new gauges is they are too "modern" looking for my old girls, we need accurate oil pressure gauges but they need to look right too, the subject of making new oil gauges for old Cats has been mooted for a long time.
Sat, Oct 24, 2020 6:14 AM
bruce oz
https://www.acmoc.org/store/restoration-parts/parts
Sat, Oct 24, 2020 10:11 AM
rax200
Mike
[quote="Mike Meyer" post=223128]Hi Daryl, do you have a photo of that 1W5353 oil gauge, I'm curious to see what the face looks like.
Mike[/quote]
Hi Mike,
Here is a photo of the new gauges
[attachment=60898]20201024_161132.jpg[/attachment]
Regards
Sat, Oct 24, 2020 2:36 PM
Thank you received: 16
Reply to rax200:
Mike[/quote]
Hi Mike,
Regards
Bruce, do those old-style gauge faces fit new, current gauges, or only the original gauges?
Sun, Oct 25, 2020 4:04 AM
Chapter 2 The Link Club's AGM
