Looks like to me, there is the top part of a 7 in front of the zero which would be a 70D 2249 # 12 grader. That would make it about a mid 1958 build. If that is not a 7, I've never heard of a 0D grader. Look at the number in front of that 0 and see what it is for sure. catskinner
The 70D/71D #12 graders replaced the 8T series in the late 1950’s. Late 8T and all 70/71s have an oil clutch for improved service life. The interesting part is that unlike the tractors, the grader oil clutch uses/shares the engine oil. The engine oil pump has a section that supplies oil to the clutch to cool and lubricate it. The system seems to work fine and was continued in the 99E series that came along about 1960.
Engine in the 70D is a version of the D318 6 cylinder developing around 100 hp. As used in the oil clutch graders, the D318 has some differences in the block and oil pan from the versions used in tractors and power units for cranes, draglines etc. but most of the other parts are the same. I think the 70D is the pony start version and the 71D is the direct electric start version.
You really need a parts book and an operators instruction book. Keep a lookout on eBay for one that covers your model and serial number.
Yes it should be correct for your grader
Doesn’t yours have a gasoline pony motor?
Even if it’s been converted to 24 volt direct electric start, it may have been done with CAT specified parts or could be generic aftermarket stuff, or even a 12 volt conversion like most folks would do today.
The signs of a full conversion are 24 volt starter and generator, hand priming pump on the fuel system and glow plugs in the precombustion chambers.
That does sound about right. It has an electric starter. I cant say I know much about older style engines. I can grasp the concepts pretty well I just dont know them yet.
Edit: It runs Diesel.
Parts manual - https://www.ebay.com/itm/Partsbook-for-Caterpillar-No-12-Motor-Grader-70D1-to-70D4309-1960-edition/142179792454?hash=item211a937646:g:MSgAAOSwiDFYKnsT
service manual - https://www.ebay.com/itm/Caterpillar-No-12-Motor-Grader-8T1-70D1-71D1-80C1-Up-Servicemens-Ref-Book-96/133429057404?hash=item1f10fdd77c:g:RQQAAOSw1XNesI0-
operator manual - https://www.ebay.com/itm/Caterpillar-Cat-12-Motor-Grader-Owner-Operator-Maintenance-Manual-S-N-70D-71D/372974453181?hash=item56d70281bd:g:uB0AAOSw3wVacyLp
Hey,
So I got the parts book and serviceman's reference book. The person selling the operators guide can shove his price where he finds his books.
My question though, what kind of oil this Grader takes? I cannot find a reference to it anywhere in the books. I did manage to find a lot of other things though. So I got that going for me!
Thanks again!
Cats Forever
If you are not particular about the quality of the manual, one is available from Jensales for $51. Photos are poor copies. Or get the pdf version downloaded for $37.
https://www.jensales.com/products/caterpillar-grader-operators-manual-ct-o-12mg70d.html
For engine oil I use 15 W 40 in my 1950 112 grader, same oil as in my green tractors. (Diesels)
