Surplus rubber pads
Surplus rubber pads
Showing 1 to 10 of 11 results
Thank you received: 254
I got lucky (for once) and got a pallet of reasonably priced, unused military tank pads.
These are the originals, unmodified single stud. We plan on putting these on Jeff’s Twenty.
Has anyone gotten away with only boring or plasma cutting a single hole into the center of the track pads? Or is it better to eliminate the single stud and thread 2 holes for an adapter plate, such as the ones a member occasionally offers for sale? The little tractor is hoping to be able to be paraded and shown without worry of damaging hard surfaces. Thoughts? TIA, JM
Fri, Jul 17, 2020 7:13 AM
crookedwrench
Send a private message to crookedwrench
We put a new Berco chains on our 4U D2. Had to punch the 7/16” pad holes to 1/2” to match the new chain. While we had the pads off we punched the hole in the center for the rubber pads. Will try to show a photo. Our pads are like the ones in your photo. [attachment=59764]6E143074-CC7E-4D60-9A12-82D2E3201786.jpg[/attachment]
Tue, Jul 21, 2020 3:49 AM
crookedwrench
Reply to crookedwrench:
We found that trying to bore the pads was impossible. Partner on tractor has a “Piranha Iron Worker” and it made short order of the 62 pads. I think we punched the center holes at 5/8” or possibly a sixteenth over? Can get the exact info if needed. I don’t think a skilled plasma cutter can match the punched holes?
Get new track bolts and a good torque wrench and have at it!
Tue, Jul 21, 2020 4:07 AM
crookedwrench
Holes for pads were 1/16” over the needed 3/4” not the previously stated 5/8
Tue, Jul 21, 2020 4:13 AM
Looks like I posted in wrong section...
Jeff M. has made a template to burn the holes.
I like the IronWorker idea, definitely a first. Beats boring holes the old fashioned way.
Your tractor is nice! Thank you, JM
Tue, Jul 21, 2020 9:42 PM
janmeermans
JM,
So your pad without using a spacer plate will only bear on the four track bolt heads? I guess that would work for just parading around. I bought my FIFTEEN pads from John in Fresno who provided plasma cut plates with six holes (4 for the track shoe bolts and two for the pad bolts.) The rubber pads were already female threaded to accept the bolts and not the singe male bolt like yours.
Let us know how it all works out.
JanM
Wed, Jul 22, 2020 4:24 AM
GrantJ
Thank you received: 7
Reply to janmeermans:
JM,
JanM
What is a "Piranha Iron Worker"? It sounds handy. Grant.
Wed, Jul 22, 2020 7:00 AM
Mike Meyer
Thank you received: 6
Reply to GrantJ:
Look on youtube Grant, I need one of them for sure, they look awesome, or better still, a buddy with one!!😆
Wed, Jul 22, 2020 7:27 AM
GrantJ
Reply to Mike Meyer:
That machine is a BEAST! Now if I just had an extra $12,000 to play with, I would buy one. (Just dreaming). Grant.
Wed, Jul 22, 2020 8:32 PM
oldtanker
Send a private message to oldtanker
[quote="juiceman"]I got lucky (for once) and got a pallet of reasonably priced, unused military tank pads.
Has anyone gotten away with only boring or plasma cutting a single hole into the center of the track pads? Or is it better to eliminate the single stud and thread 2 holes for an adapter plate, such as the ones a member occasionally offers for sale? The little tractor is hoping to be able to be paraded and shown without worry of damaging hard surfaces. Thoughts? TIA, JM[/quote]
Them ain't tank pads. Look like PC pads. But they should work OK for the intended task. Darned things are pretty tuff. We use to call the breaded veal and chicken patties served in the mess hall track pads.......they were about as tuff as the track pads. And shapec just about the same as the actual tank track pads.
Rick
Wed, Jul 22, 2020 10:11 PM
Thank you received: 31
Reply to oldtanker:
Rick
Hi oldtanker
we used to get those darned round de-hydrated veal paddies too--we called them Pucks.
My stomach has still not recovered from them or those etherized eggs--after burps were ether flavored--sheesh.
Memories.
Regards,
17th Construction Squadron, Royal Australian Engineers, Plant Operator/Fitter, SVN, May'68-'69.
Thu, Jul 23, 2020 8:12 AM
