Reply to jw45:
the cyclinder head iam working on has a #stamped on it #3F8803 then to the right of it towards the t stat housing it has the letters LG can anyone tell me what machine it came off of the pre combustion chamber o rings are a different size than the one on my machine its machine #9U26429 which is a 1957 model will these heads interchange also on one of the pre combustion chambers it is marked DD does that indicate a size thanks jw45
Check that stamped number again...if it reads 3F9903 that is a casting number for an early 5F1305 part number head.
The 5F1305 head was replaced in 1952 with a 1H7659 (service replacement) unit at serial number 9U11075-up.
The later head uses a different chamber retainer and gasket rings. The old outer ring seal #4F5607 became the new inner ring seal and a new 2H3086 outer ring seal is used.
The LG may stand for the "G" series industrial engine.
DD may be an indicator for after market size.....but they all used the #4F8517 chamber unless it is a glow plug model.
If your unit uses the later style one piece chambers then you would only need the 2H3086 ring seals.
