Hi, langlc06.
I don't have the specs you need but I suspect that somebody will turn up with them soon.
I just want to make sure that you know that these machines DO NOT have a differential. That tandem drive is a LOCKED UP system to ensure that all four wheels drive ALL the time. For this reason, it is advised to keep all 4 tires on the drive as equal as possible at all times, preferably matched from new, in order to reduce strain on the drive axles and the chains in the tandem cases.
Yep understood. I should have used the term final drive i think. It is a pain cribbing up the entire rear end of the grader to get the chains off of one side.
Anyone have any thoughts on the shim specs?
Hi, langlc06.
If you can lift the front wheels around 18" off the ground with the blade, you can raise either side of the tandems.
To do this, set the blade square across the machine and centered under the frame. Then raise the front end about 18"off the ground. When you have this done, 'raise' the blade on the side AWAY from the tandem that you want to lift. The balance of the machine will cause the tandem on the side away from the one on which you 'raised' the blade to come off the ground.
Then crib away to your heart's content.
If the controls are so worn that you can't lift the front by using both controls together, try using them alternately, one at a time.
You may find some useful information in this 'ar-tickle'. (Then again, you may not. LOL.)
http://www.acmoc.org/bb/showthread.php?20409-Cat-12-Graders-Pre-G-series
Cats Forever
Are you removing the tandem axle or how much are you removing and replacing? I am not the expert but I have never seen a service manual for the tandem drive, only a short supplemental manual for the transmission.
Hello,
I am only tearing down to the tandem bearing behind the sprocket. The axle, bearings, and seals, appear to be good on the final drive assembly. I wasn't going to tear down further unless the axle ended up being out of true.
Cats Forever
