Caterpillar Ball and Roller Bearing Conversions
Showing 1 to 10 of 18 results
these scans are of charts for conversion of Cat Part Numbers to/from Hyatt/New Departure Ball and Roller Bearings.
May load out of sequence as there are some 7 pages.
Sorry, seem to be loaded in reverse!!!!!!!!!
Sun, Jun 21, 2020 12:09 PM
Deebo
Librarian
Thank you received: 38
Awesome, Eddie. Thanks very much, that info goes nicely with the Accessory and Supply catalogue 1937-1944 here;
http://www.tractorparts.com/PDFs/ACCESSORY_AND_SUPPLY_CATALOG_1937THRU1944.pdf
Regards,
Tony
Sun, Jun 21, 2020 2:39 PM
Reply to Deebo:
Regards,
Tony
Hi Tony,
thanks for that link--I am lucky enough to have been gifted one of these by one of our long time and then retiring Parts Dept. Gentleman (Charles Marshall, RIP)
Way back then he thought I could use it more so than anyone else he knew at The Dealership.
Pages seem to Date range between 1938 and 1948 in my one and is around 2.5" thick.
Which also now reminds me that there are some 6 pages of Anti Friction Bearings of various extinct makers in there too--will get these done soon too.
Thanks and Cheers,
Mon, Jun 22, 2020 7:52 AM
Reply to edb:
Hi Tony,
Thanks and Cheers,
just now seen that the same apparent title comes up for two separate posts on the bearings---due to shortening of the titles in the Titles pane--cannot win can I.
One is for Applications and one for Conversions so check and save both.
I will remove the Caterpillar and see what we get.
EDIT--seems we cannot edit titles once loaded
Mon, Jun 22, 2020 8:11 AM
Deebo
Librarian
Reply to edb:
Hi Tony,
Thanks and Cheers,
[quote="edb"]Hi Tony,
Thanks and Cheers,
Eddie B.[/quote]
Wow, Eddie, that’s a historical document! With that and a NPR I’d be set for life.. Would make things a lot easier..
Mon, Jun 22, 2020 3:02 PM
Machias cat
Send a private message to Machias cat
Reply to Deebo:
Thanks and Cheers,
Eddie B.[/quote]
Platinum encrusted with large, fine diamonds!
Thanks, Eddie and Tony.
Anybody into the early cats should download this info post haste.
Tue, Aug 4, 2020 2:57 AM
Reply to Machias cat:
Boot to the top again.
These charts or at least the link should be downloaded to your computers for easy reference in the future.
https://www.acmoc.org/bb/discussion-d72/26787-caterpillar-ball-and-roller-bearing-conversions#219292
Wed, Nov 11, 2020 5:33 AM
Mike Meyer
Reply to edb:
Deebo, are you able to convert Eddies pages into a single PDF like you did with the oil filter info, that makes printing them so much easier.
Mike
Thu, Nov 12, 2020 2:29 AM
Deebo
Librarian
Reply to Mike Meyer:
Mike
No problem, Mike, will do! Fingers crossed I can remember how I did it..
Tony
Thu, Nov 12, 2020 3:56 PM
Mike Meyer
Reply to Deebo:
Tony
Thanks Tony
Thu, Nov 12, 2020 4:34 PM
Deebo
Librarian
Here's a PDF version for anyone that prefers that format.
Tony [attachment=61031]CAT bearing conversion charts.pdf[/attachment]
Fri, Nov 13, 2020 12:25 AM
