D8H alternator conversion help
Showing 1 to 10 of 14 results
treestandman
Send a private message to treestandman
I was wondering if anyone out there know's where to get the alternator conversion bracket for a older d8h, or if some one has a picture or drawing of one, so I can get an idea of what one looks like so I can make one.
Mon, Jun 15, 2020 8:42 AM
Are you referring to one of these?
Tue, Jun 16, 2020 12:07 PM
kittyman1
isn't that a nice Delco conversion Magneto?
maybe it should be yellow
Tue, Jun 16, 2020 12:15 PM
treestandman
Ya that's the one I'm looking for can't seem to find one up here in the great north
Wed, Jun 17, 2020 6:49 AM
Reply to treestandman:
Not handy to you but I believe "Florin Tractor" in Ca. stocks them, they are a bit pricey but built right with cooling fan and flex coupling. You will need to have the gear train and drive gear as that's not part of the package.
Wed, Jun 17, 2020 6:58 AM
D6c76a
Send a private message to D6c76a
GM 1 wire alternator, fabricate your bracket to suit your belts. Simple ,no fancy hard to find $ parts. Done.
Wed, Jun 17, 2020 9:39 AM
kittyman1
Reply to D6c76a:
Yes, X 2 !
Wed, Jun 17, 2020 10:09 AM
Eds-oldiron
Send a private message to Eds-oldiron
C C Battery was making this conversion years ago, along with the helix starter drives. Might try them. https://www.ccbattery.com/index.php
Wed, Jun 17, 2020 6:59 PM
treestandman
Reply to Eds-oldiron:
Thanks guys for the help, I will get in contact with the suppliers you guys have suggested and see if still available and see what the price is.
If it is to crazy I will fab one up now that I know what it looks like,
Virgil
Wed, Jun 17, 2020 11:54 PM
Virgil
Cut down gutted generator housing is also an option....
Thu, Jun 18, 2020 12:19 AM
treestandman
I like that option,
I have access to a burnt d8, so I might scoop the generator from it and try to build one just like the pic
The one thing I don't understand is the 1 wire alternator, is that a new thing out?
I sure appreciate the help guys
Thu, Jun 18, 2020 7:35 AM
