Cat D2-5U 2A cutting edge
Cysco
Latest project which I anticipated to be straight forward was not.....I needed to replace the worn cutting edge and end bits but found the center was not available and the end bits I did find in Australia. I emailed that company a coupe times but never received a reply. Oh well ………
I did some research for the specs and found a Case 1150 (and others) had the same specs for the center but was longer. That was an easy trim to fit. The end bits I had made as the on center bolt holes were really odd. Got a fresh set of Cat plow bolts and now ready to cut instead of scooting across this hard clay...…. 😊
Have a good day....Bill
Note......will someone smarter than me please turn picture ……..thanks!
Thu, Jun 4, 2020 4:33 AM
Thank you received: 24
Looks good Bill, I have a new set of edges on my 2S, although I was able to source all three parts and the hardware from Cat.
Thu, Jun 4, 2020 5:38 AM
seyser
Looks really nice!
Thu, Jun 4, 2020 8:18 AM
Earlcoate Charity Open Day
