Big Gear Box
Big Gear Box
Showing 1 to 10 of 16 results
Oil Slick
I delivered a 40,000 lb gear reduction box to Canada. I’m learning to ask more key questions. The electric motor input speed of 1,750 and output of the two opposing rotating screws is 350 rpm. The gear reduction box turn two screws opposite directions to mix the plastic materials. The screws force the blended plastic out small holes and a cold knife cuts them off at 3/16. The cold knife cuts small pieces so it almost instantly hardens the plastic. This facility looks like a oil refinery. They make tons and tons of little plastic thats loaded into RR hopper cars. Didn’t ask what happened after that. Assume it’s put into some type of die press to make plastic goods.
D4e, these Michigan truckers are daily heavy haulers.
Headed to Dallas now with a low tolerance wood CNC machine that makes household furniture.
The forklift is in demand. They keep it very busy. It’s a 60-80 ton lift. They stack weights on the rear and it hydraulically extends out as needed. Steel plates were needed to keep it from sinking in the asphalt but no problem on concrete.
Sat, May 16, 2020 7:55 AM
Norm R2,22
Send a private message to Norm R2,22
In Mich. they are allowed 11 axles. I think the guy that wrote that law owned a tire store. I was helping at a farm near Flint. The rig I was driving had a 3 axle tractor, 5 axle trailer (two lift axles) and a 2 axle pup. Lots of fun going through town with that rig.
Sat, May 16, 2020 10:33 AM
old-iron-habit
Reply to Norm R2,22:
Where did you cross into Canada at? No problem with Weinie dog with the border shutdown to all but commercial traffic?
Sat, May 16, 2020 1:29 PM
Oil Slick
Reply to old-iron-habit:
Norm, how much can they gross with 11 axles?
Rodger, Weenie kicked the bucket few years ago. Got little Chihuahua now. I crossed at Port Huron (above Detroit) I make the dog stay in the back and deny everything. She loves to ride on my Harley with me. She rides in my back pack.
Sat, May 16, 2020 8:21 PM
Reply to Oil Slick:
Heres an old Michigan roller.
Sat, May 16, 2020 8:30 PM
Norm R2,22
I seem to remember 154,000, but that was going to Ottawa Lake, Mich. and I think that was a bit over.
Sat, May 16, 2020 11:05 PM
Thank you received: 98
Hi, Oil Slick.
I dunno about elsewhere but we hadda 9-axle come into the ranch here with a load travelling entirely within CA. that was carrying 106,000#. And it was not all one piece. One part had to be taken off to get the height down but still came over in the same load. I do not know what the gross was.
Sun, May 17, 2020 4:37 AM
Oil Slick
Hi, Oil Slick.
Rome, the old COE doesn’t look very powerful but with enough gear reduction seems like one drive axle would chew up tires pretty fast with that much weight.
Deas, did the ranch get a new play toy?
Sun, May 17, 2020 9:54 AM
Norm R2,22
Reply to Oil Slick:
It's been said that the biggest hills in Mich. are overpasses. 😙
Sun, May 17, 2020 10:30 AM
There is some good grades going up to the UP, but not many big loads go up there.
Sun, May 17, 2020 7:49 PM
Reply to Oil Slick:
[quote="Oil Slick"]Rome, the old COE doesn’t look very powerful but with enough gear reduction seems like one drive axle would chew up tires pretty fast with that much weight.
Dead, did the ranch get a new play toy?[/quote]
That might have been just a local runner. I wouldn't want to go very far in that little cab! lol
Sun, May 17, 2020 7:51 PM
