Cat Hi-Way Yellow
Cat Hi-Way Yellow
Showing 1 to 10 of 28 results
85CW
Send a private message to 85CW
Hello all,
I hope that you are all well. I have a simple question, that may not be easily answered. Is there a CURRENT vender that sells the Cat Hi-Way Yellow? I have read quite a few past threads and it seemed like there were some old paint products that were in the past available. I am wondering if there are any available now without having a custom mix using the ACMOC store paint chip. I have a running D2 5j and want to clean her up a bit, but not trying to restore or enter into any judging show..
Thanks,
Paul
Fri, May 8, 2020 5:44 AM
jstandle
Send a private message to jstandle
Fri, May 8, 2020 10:58 PM
85CW
Hey thanks for the info!!
Sat, May 9, 2020 9:21 AM
Reply to 85CW:
I have been using valspar tractor and implement high gloss enamel---4431-08--equipment yellow-matches very well
Sat, May 9, 2020 9:05 PM
Thank you received: 11
Reply to dpendzic:
Hi, 85CW.
I don't know just how close it is to the original hi-way yellow but Rustoleum make a spray pack that they call 'Old Caterpillar Yellow - found in most hardware stores with a 1/2-way decent paints section. Or ask for it.
Sat, May 9, 2020 11:05 PM
85CW
Hi, 85CW.
Thanks all,
Just the info I was looking for!
Sat, May 9, 2020 11:11 PM
rhartwick
Send a private message to rhartwick
Reply to 85CW:
Thanks all,
Deas,
Like 85, I have been looking for some regular enamel off the shelf. The Rustoleum "Old Cat Yellow" has been discontinued, at least in the US, without a replacement. I ordered a quart of the Ag Parts stuff mentioned above, just to see how close it is. Should be in next week. I'll try to post a picture once I try it out to see how far off it is.
Sun, May 10, 2020 8:18 AM
Reply to rhartwick:
Deas,
http://paintref.com/cgi-bin/colorcodedisplay.cgi?manuf=Caterpillar
This chart may or may not help.
Sun, May 10, 2020 9:41 AM
8C 361
Reply to edb:
I have spray cans of Rust-Oleum Old Cat yellow that I ordered online, maybe Amazon. The color is perfect. It did come from Canada. I had the number written down but can't find it right now.
Sun, May 10, 2020 8:01 PM
rhartwick
Reply to 8C 361:
The catalog number I found for Rustoleum Old Cat Yellow was 245500. I went online to Rustoleum, and they listed that as discontinued. So far, the only paint advertising itself as Old Cat Yellow has been the Ag State one. Valspar might have some as well, as mentioned above, but with TSC not carrying that line, I haven't been able to find any at a retail store, in the US at least. Whenever I see a yellow in a machine enamel I buy a small can of it to try. Yellow must be a hard color to match, because all the various Rustoleum yellows look pretty weird when comparing a painted part to the real Cat color.
Sun, May 10, 2020 8:47 PM
Reply to rhartwick:
yes the valspar i order on line---it used to be called caterpillar yellow but there was a problem with copywrite with cat
Mon, May 11, 2020 3:50 AM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
