Sealant on gaskets?
Sealant on gaskets?
Showing 1 to 6 of 6 results
Cat Yellow1
Send a private message to Cat Yellow1
Thank you received: 6
I'm about to put the manifold, flange, and cover over the timing gears. I'm not planning to use a sealant but got to wondering if it would be a good idea. What do you all think? Gaskets are not from Cat.
Thu, Apr 16, 2020 7:18 AM
bernie
Several good posts on this you can find under search option. More than I could help with here.
Advance Search “permatex”
Thu, Apr 16, 2020 8:33 AM
Cat sells Permatex hi-tack sealant. or any auto parts store.
Thu, Apr 16, 2020 8:35 AM
bursitis
depends on the gasket and application. some are better left without,especially if you need to remove in the future.
Thu, Apr 16, 2020 9:45 AM
mog5858
Reply to bursitis:
if you feel the need only do one side if you ever have to take it off that way you have a better chance of not wrecking the gasket.
Thu, Apr 16, 2020 9:56 AM
sheddcanyon
Send a private message to sheddcanyon
Reply to mog5858:
I think Squatch253 gives some solid advice on this.
https://www.youtube.com/watch?v=ymlsF2bdEJ8&list=PLW_TtiTWGCaqa-leidqLnhB35AX3g-XUE&index=41&t=0s
Thu, Apr 16, 2020 10:23 AM
u-joint
Send a private message to u-joint
Reply to sheddcanyon:
It's real simple. If you have to use silicone with a gasket to get it to seal something is wrong and it won't seal anyway! Dry gaskets used will let 2 parts bond as one. Put silicone in the mix and your 2 parts will not bond as one. The silicone will let the 2 parts move separate from each other. I absolutely would not use it on a heavy cast block to a heavy cast timing cover? Silicone works real well on your bathtub!
Thu, Apr 16, 2020 1:05 PM
