Can i run cheap tractor supply hydraulic oil in Cat 955L
Showing 1 to 6 of 6 results
cg3p0
Send a private message to cg3p0
I had picked up a bunch of it from tractor supply not really knowing what i was doing, now im questioning if i should use it or not.
It is this stuff
https://www.tractorsupply.com/tsc/product/traveller-premium-universal-tractor-trans-hydraulic-fluid
Book calls for a 10W for the hydraulic system which is what i would be using it for
This stuff is 10W-30
Is it going to hurt to run that or should i take it back for something else. Hydraulic system takes a lot of oil, trying to $ave $ but dont want to break it with the wrong stuff.
Tue, Apr 7, 2020 11:04 PM
I use that stuff in my wheeled tractors where the trans and hydraulic system use the same oil--but in my dozers i use hydraulic oil in the hydraulic system--R&O aw 46 which i get in Sams club--I think TSC has a standard hydraulic oil also
[attachment=58068]Viscosity-Chart.jpg[/attachment]
Tue, Apr 7, 2020 11:59 PM
It should be fine. Additive package is more extensive in that than a straight hydraulic oil so I think it will be fine where you don’t have clutches and brakes.
I am using some in my 922b wheel loader. I had the main hydraulic hose between filter and valve in the tank burst the other day. By the time I realized it, there wasn’t much left and it needed changing anyway!
I didn’t have a book at the time and I just grabbed 15 gallons when I had the new hose made thinking it probably held about 10. Well that 15 gallons disappeared and no sign of the oil in the fill neck so I grabbed another 5......that disappeared too. Operators manual came in the mail and it says capacity is 25!
Also has a procedure to get the maximum amount of the oil out of the system which I couldn’t do because the hose had burst, but I’ll know next time.
Wed, Apr 8, 2020 1:00 AM
Wed, Apr 8, 2020 1:07 AM
Original spec for hydraulic system is SAE10W. Closer to a ISO 32. ISO 46 will be slow to pump at cold temperatures.
Wed, Apr 8, 2020 1:40 AM
cg3p0
Thanks guys! I was just reading another forum of a guy having problems with too thick of an oil in the hydraulics. I dont want to deal with that. I think im going to take it back and get iso 32. Rural King carries it cheap.
https://www.ruralking.com/harvest-king-antiwear-hydraulic-oil-aw32-10w-5-gallon-pail#
Wed, Apr 8, 2020 2:15 AM
Reply to cg3p0:
"mo" is Missouri?
I wouldn't think a slightly thicker oil in an older system would hurt?
Thu, Apr 9, 2020 5:58 AM
| Hartley - South Australia
