OT Dayton Fayette Trailer Brake Drum
Showing 1 to 6 of 6 results
daron
Dayton Fayette trailer brake drum 122369-a 12 1/4" 1980
Is this brake drum cast steel or cast iron? I want to use it as a 'reducer' for a mail box 'post' and weld it to a large earthmover wheel.
Thanks, Daron
Wed, Apr 1, 2020 5:20 AM
Do the grinder spark test to check if cast steel or iron.
Wed, Apr 1, 2020 9:40 AM
Oil Slick
OM, please give us another sentence or two on the grinder test.
Thu, Apr 2, 2020 6:56 PM
Skip in CT
Send a private message to Skip in CT
Reply to Oil Slick:
Weld a bolt on the inside where it wont be in the way and hit it with a hammer. if it stays it's steel.
Skip in CT
Thu, Apr 2, 2020 9:11 PM
Reply to Oil Slick:
Take your portable grinder to the metal in question and identify the spark pattern. There are u-tube videos on the net that show the process in color.
Thu, Apr 2, 2020 10:00 PM
Only Phil Swift can cut a aluminum boat in half and make sparks! lol at 0:22
https://youtu.be/ktszKiEh0fo
Thu, Apr 2, 2020 10:44 PM
daron
OM-
Last evening, after the sun wasn't interfering so much, (and i retrieved a document saved years ago explaining spark tests) I got very small short stream sparks vs much longer sparks from known steel samples. Oh well, back to the scrap pile to try to find something to do what I'm trying to do.
Thanks, Daron
Mike- Emily is working for Berry (I hope I spelled it right) from home now
Thu, Apr 2, 2020 11:08 PM
