pony engine swap
pony engine swap
CableCat
Send a private message to CableCat
Will the pony engine off a d337 engine for a dw21 scraper be the same as the one on my 17a d7? From what i can see, they look the same, without having them side by side. If so, What all other machines used that same pony?
Thanks,
Jim
Fri, Feb 21, 2020 8:29 AM
old-iron-habit
[quote="CableCat"]Will the pony engine off a d337 engine for a dw21 scraper be the same as the one on my 17a d7? From what i can see, they look the same, without having them side by side. If so, What all other machines used that same pony?
Thanks,
Jim[/quote]
The 3T D7s and the 2U D8s share a pony. Not sure if they carried thru to the newer models with ponies.
Fri, Feb 21, 2020 8:51 AM
gemdozer
Thank you received: 7
Reply to old-iron-habit:
Thanks,
Jim[/quote]
The w21 starting engine fit on d7-17a,d8 14-15a,d9-18-19a. and fit for some power units,but not the cluch housing.
Fri, Feb 21, 2020 7:06 PM
Chapter 2 The Link Club's AGM
