Hardware part numbers to description reference?
Showing 1 to 10 of 13 results
Does anyone know if there is a listing of hardware part numbers (bolts, screws, washers, nuts etc) with a description of what they are (size, length, thread, grade, etc)? I am restoring my CAT22, 2F5209, and am frequently finding myself unsure of the bolt lengths, etc. Also, are all CAT bolts grade 8? Thanks, Ray
Sun, Feb 9, 2020 7:55 AM
bernie
Search “One Safe Source CAT” for a downloadable .pdf. Not sure if it’ll get you everything, but close. Use “find” selection for the .pdf to find what you want. Some part numbers less than four ending characters will add zeros to make them so.
Good luck-
Bernie
Sun, Feb 9, 2020 12:53 PM
Peter C
Send a private message to Peter C
Reply to bernie:
Good luck-
Bernie
Ray, try this. I have found this very useful in assembling my 22 from the "basket" that it came in. Not sure where it came from; I think from here some years ago. I also have 12 pages that I think were copied from a Cat book. PM your email to me and I will send them to you if you want more.
Pete
[attachment=57096]bolts_nuts_washer.jpg[/attachment] [attachment=57097]bolts, etc. part numbers.jpg[/attachment]
Mon, Feb 10, 2020 12:21 AM
kittyman1
- i was wondering this too, are most bolts at least a Grade 8 ??
Mon, Feb 10, 2020 2:05 AM
Reply to kittyman1:
Note when ordering bolts sometimes you have to add a number to the part number:
S-467 should be 0S-0467
Mon, Feb 10, 2020 2:14 AM
seiscat
Everything you always wanted to know about Caterpillar hardware but were afraid to ask...
[attachment=57100]hdw 1.jpg[/attachment] [attachment=57101]hdw 2.jpg[/attachment] [attachment=57102]hdw 3.jpg[/attachment] [attachment=57103]hdw 4.jpg[/attachment] [attachment=57104]hdw 5.jpg[/attachment] [attachment=57105]hdw 6.jpg[/attachment] [attachment=57106]hdw 7.jpg[/attachment] [attachment=57107]hdw 8.jpg[/attachment]
[attachment=57108]hdw 9.jpg[/attachment] [attachment=57109]hdw 10.jpg[/attachment] [attachment=57110]hdw M.jpg[/attachment] [attachment=57111]hdw MN.jpg[/attachment]
These are from a "One Safe Source" in the 1990's,
Craig
Mon, Feb 10, 2020 3:26 AM
Reply to seiscat:
Craig
at a guess from what I was told at The Dealer that machines built before at the latest 1960 the bolts used were of a tensile strength that matched the application --ie, foot plate, side cover etc bolts were low Grade. More stressed application uses needed bolts of a higher specification hence there could be a at least two part Numbers for a particular sized bolt.
I think some bolts had a raised line on one side of the bolt head face to indicate a special bolt.
At The Dealer we had to keep bolts from each area of a machine separate to save fitting a low strength bolt into a high strength application. I asked what if they had been mixed before and got that blank look.
Later on Cat made all their hardware--bolts etc, to be Grade 8 or better to stop the use of incorrect spec bolts.
I seem to recall a Serv Magazine or such, maybe it was in a SRB, telling of this change and of the dangers of using incorrect spec bolts.
Mon, Feb 10, 2020 6:11 AM
Reply to Peter C:
Pete
[quote="Peter C"]Ray, try this. I have found this very useful in assembling my 22 from the "basket" that it came in. Not sure where it came from; I think from here some years ago. I also have 12 pages that I think were copied from a Cat book. PM your email to me and I will send them to you if you want more.
Pete
[/quote]
Pete,
Thanks much. See your PM.
Ray
Mon, Feb 10, 2020 10:11 AM
Reply to seiscat:
Craig
[quote="seiscat"]Everything you always wanted to know about Caterpillar hardware but were afraid to ask...
Craig[/quote]
Craig, I think this is just what I need. Unfortunately, when I print them out is is very difficult to read them. Do you have them in higher resolution, or electronically that you can email to me at [email protected]?
Mon, Feb 10, 2020 10:13 AM
oldbeek
Reply to seiscat:
Craig
Craig[/quote]. That was a great book. very handy to bad it isn't around anymore.
Mon, Feb 10, 2020 11:37 AM
seiscat
Reply to oldbeek:
I just got around to reading this post, sorry. I had not tried to print these scans and did not realize the quality was poor. I will scan them again and post them again later today.
Craig
Tue, Feb 11, 2020 1:21 AM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
