Login | Register
Fuel guage
Fuel guage
Showing 1 to 10 of 16 results
railroadjoe220
Send a private message to railroadjoe220
I have a D257 I need to make a fuel dip stick for the seat tank.Could someone tell me the lengh ,how the gallons are marked on it.Inches from the bottom that the gallons are marked off.
Thu, Jan 4, 2007 8:27 AM
Hi RR Joe,
I was able to track down the dimensions for both the early and late D2 seat tanks. Which one do you need? the early pre-#13,237 20 gallon tank or the later 26 gallon model. Let me know and I will email the info to you.
Mon, Jan 8, 2007 11:14 AM
yellercat
Send a private message to yellercat
railroad joe has a good question there. Needing the same information for my D6-9U Mag', can you assist?? It is a seat tank of course, but those contours really make it difficult to guess the gallons remaining in there. Its good information to have when you try to keep the tank full after every run and need to schedule the fuel truck to fill the (230 gallon) stand tank.
Any thoughts on what would be best to make the 'dipstick' out of?
tanks-
Mon, Jan 8, 2007 7:44 PM
Reply to yellercat:
tanks-
Hi yellercat,
Yes, I can get you the dimensions. Was going to do it today but forgot.
Tomorrow should do it.
Tue, Jan 9, 2007 8:14 AM
yellercat
Hi yellercat,
No hassle Ole Mag' , whenever you can get around to it. I'll make a note and put it with my other notes. Length and marks from top or bottom (or both) will get me there.
Any idears on what to fab it from?
yellerc@
Tue, Jan 9, 2007 9:36 AM
Reply to yellercat:
yellerc@
OK guys,
Here's the dip stick dimensions. I would suggest stainless steel if you can get it but probably will have to be sheared to get the 5/16 width. Would also recommend a little thicker than the .050 in. Kinda limited cause the hole for the dipstick is only 3/8 in. diameter.
Thu, Jan 11, 2007 11:18 AM
Dozerman51
OK guys,
I had a friend of mine who is a metal fabricator make one up for me using my old one as a guide. To mark the gallon amounts on the plunger I used steel stamping numbers and stamped them onto the stainless steel plunger.
Thu, Jan 11, 2007 1:19 PM
Nico Ensink
Send a private message to Nico Ensink
Reply to Dozerman51:
Hi O.M.
While you seem to have details handy, would you have similar info for a D4 7U12815 with tank seat?
Would be nice info to store somewhere handy on the board.😄
Thanks in advance if you have,
Nico
Thu, Jan 11, 2007 11:27 PM
Reply to Nico Ensink:
Hi O.M.
Nico
OK,
Guess I should add both the seat and side tank models D4's. Give me a day or so.
I have given up on this BB ever developing an archive section. It has been a discussion item for years. Doing good just to keep the lights on 😉 😉
Thu, Jan 11, 2007 11:54 PM
railroadjoe220
OK,
Pete,
Thanks for the information,just what I needed.
Joe
Fri, Jan 12, 2007 8:34 PM
yellercat
Reply to railroadjoe220:
Pete,
Joe
'Mag' -
Many thanks from me, (and all the other BB members who will print and 'archive' on their own), for the professional quality information on this item; along with the other information that you so freely put out for all of our use and enjoyment! You are doing more than your share to keep our hobby alive. We appreciate you time and efforts!
yellerc@
Fri, Jan 12, 2007 8:59 PM
KORUMBURRA WORKING HORSE & TRACTOR & 100 YEARS OF CAT RALLY
| 5875 STH GIPPSLAND HWY, NYORA
Booleroo 2025
CAFES 2025 TULARE, CALIFORNIA
| Tulare, California
| 34 Henty Hwy, Warracknabeal
