railroad joe has a good question there. Needing the same information for my D6-9U Mag', can you assist?? It is a seat tank of course, but those contours really make it difficult to guess the gallons remaining in there. Its good information to have when you try to keep the tank full after every run and need to schedule the fuel truck to fill the (230 gallon) stand tank.
Any thoughts on what would be best to make the 'dipstick' out of?
tanks-
Hi yellercat,
Yes, I can get you the dimensions. Was going to do it today but forgot.
Tomorrow should do it.
No hassle Ole Mag' , whenever you can get around to it. I'll make a note and put it with my other notes. Length and marks from top or bottom (or both) will get me there.
Any idears on what to fab it from?
yellerc@
OK guys,
Here's the dip stick dimensions. I would suggest stainless steel if you can get it but probably will have to be sheared to get the 5/16 width. Would also recommend a little thicker than the .050 in. Kinda limited cause the hole for the dipstick is only 3/8 in. diameter.
I had a friend of mine who is a metal fabricator make one up for me using my old one as a guide. To mark the gallon amounts on the plunger I used steel stamping numbers and stamped them onto the stainless steel plunger.
Hi O.M.
While you seem to have details handy, would you have similar info for a D4 7U12815 with tank seat?
Would be nice info to store somewhere handy on the board.😄
Thanks in advance if you have,
Nico
OK,
Guess I should add both the seat and side tank models D4's. Give me a day or so.
I have given up on this BB ever developing an archive section. It has been a discussion item for years. Doing good just to keep the lights on 😉 😉
Pete,
Thanks for the information,just what I needed.
Joe
