Disconnect Switch on New Truck
Showing 1 to 10 of 13 results
Oil Slick
I’ve seen trucks burn to the ground from electric fires and I’m often working on it. It’s a pain to disconnect the batteries. I would like to put a disconnect switch on my 2015 KW. It has 4 batteries with two ground cables running to the starter. The cable ends are 5/8 and the disconnect switch is 3/8. Any problems you see with putting two 5/8 cables on one 3/8 stud? Then running two cables down to the starter with the proper size ends. Or any problems putting a disconnect switch in?
Thanks for the help again.
Fri, Jan 24, 2020 11:43 AM
Thank you received: 39
Step up to a Cole Hersee #75908 switch. Higher amperage rating, silver contacts and 1/2" studs. Having a battery disconnect switch is one of the best moves you can make.
Fri, Jan 24, 2020 12:37 PM
1951D2
We at the County had a shop burn down a few years back from a unit with this issue, so we put disconnect switches on everything after that. Now all the Cat ,John Deer and new plow trucks come with them from the factory. Actually the Cat and John Deer equipment have come with them for years. Far as I am concerned everything should have them.
It is also much quicker to do welding repairs when you have them. Turn it off do your repairs and then turn it back on and your out on the road again, with no chances of hurting the newer electrical systems.
Sat, Jan 25, 2020 8:21 AM
Oil Slick
Reply to 1951D2:
Thanks guys. Got the 200amp switch. Much better with 1/2 studs. Only cost $65. Why does Cat always put the switch on the ground cable and not positive?
Sat, Jan 25, 2020 10:27 AM
I don’t think it really matters which side you disconnect. You could say that with the disconnect near the starter you could still have one of the long positive cables short to the frame somehow and still cause a fire even with the disconnect open. If you open the ground side there’s nothing for a bad positive cable to short to and a bad ground cable can’t short to the frame anyway since it’s normally connected already .
Guess I’ve never had a fire, I usually install a disconnect to keep a small drain from killing the batteries over a period of days or weeks sitting. I like to put the disconnect near the battery box under drivers door, but that doesn’t always work out if there’s a second box on the passenger side. I’ve got a 4WD tractor that I would like to put one on just because I think it’s a good idea, but it has multiple grounds that I think will require a couple disconnects. So far it’s not causing any problems so I haven’t done it.
Sat, Jan 25, 2020 9:21 PM
Thank you received: 237
Here ya go Mike. Paccar factory disconnect switches. My older 2002 had a pair of them mounted through the floor left of the driver seat. Pull up and twist to disconnect...
Flaming River brand from factory outside of battery box. Have them in all of the trucks but never use them!
Had one KW go into shop and mechanics said we had electrical issue with the T-800; NO POWER...
Last mechanic worked on it and parked it, with powered OFF position, as he didn’t know how soon we would pickup the unit. And I wonder why we pay a shop over $165.00 an hour to “repair” trucks? They had 3 “technicians “ scratching their heads with the diagnostic tool plugged to the port...unreal.
Sun, Jan 26, 2020 2:56 AM
Oil Slick
Juice, technician today have no trouble shooting skills.
Another Mercer driver had his Paccar truck catch fire going down the road so I put mine by the seat. Only cost $105. Switch 65 cables 40. Already had the 49/64 drill bit.
Sun, Jan 26, 2020 4:46 AM
Reply to Oil Slick:
all of our fire engines come with a master switch--don't know if its on the ground or hot leg
Sun, Jan 26, 2020 5:11 AM
rmyram
hey mike,
ground side switching has a smaller arc when contacts are broken with current running through the circuit. a lot of manufacturers have used it over the years. its a head scratcher when you haven't worked on one before. I worked on a kenworth that was late 90's early 2000's about 15 years ago, the owner had installed rotating beacons for wide loads and they only would work for about 5 minutes before it starte popping the circuit breakers, and they would come on when you stepped on the brakes etc, turned out, that entire truck was wired with ground side switching, and the owner had installed the light circuit with positive side switching, he had used a common ground so his circuit was powering up others and vice versa, had caused lots of weird symptoms.
Deere/hitachi excavators also used ground side switching which caused funny symptoms when the switch failed closed or the wiring harness rubbed through causing a short to ground.
night switches are great, and i have only seen them in the ground side of a machine for the reasons mentioned below, take the ground side off and nothing can short to ground and cause arcing/fires.
Sun, Jan 26, 2020 10:59 PM
Andrew
Reply to rmyram:
hey mike,
Most of the master switches used here on trucks and machinery are a big thing, about 6" x 6" with a Tee handle .
No doubt originating in the USA .
These isolate both sides of the circuit .
Mon, Jan 27, 2020 4:06 AM
Reply to Oil Slick:
That switch is rated 2000 amp intermittent (30 seconds) and 300 amp continuous.
Mon, Jan 27, 2020 5:50 AM
