Cat 3204 on 943 19z engine having problems FIRE
Showing 1 to 10 of 34 results
uisum
Send a private message to uisum
Hello to all .
I have a 943 charger.
The engine has serious problems. Difficulty turning on.
Smoke comes out of the oil vent.
No water in the oil. And not oil in the radiator.
There appears to be no more compression in some cylinders.
Maybe the piston rings?
A lot of fire and a lot of smoke comes out of the 2 and 3 exhausts.
What could I check before taking the head apart.
I attach video.
Thanks so much
[video]https://www.youtube.com/watch?v=b4AYPfmDbow[/video]
Wed, Jan 15, 2020 6:43 PM
Bad fuel nozzles and hole burnt through piston.
Wed, Jan 15, 2020 9:39 PM
Pull injectors and have them checked
Adjust valves
You’re probably going to need an engine overhaul though. 3204 is not one of the longest lived engines made.
Wed, Jan 15, 2020 9:43 PM
BobPV15
Send a private message to BobPV15
Adjust valves
I would check the injection timing, could be late.
Thu, Jan 16, 2020 1:52 AM
uisum
Reply to BobPV15:
Hello, makes noise and a lot of smoke at a minimum. when the engine is at maximum the smoke decreases.
Can I possibly replace the pistons and cylinders without removing the engine?
Ths
Thu, Jan 16, 2020 12:36 PM
3204 doesn’t have cylinder sleeves unless it’s been bored out and dry sleeves installed in a machine shop during a previous overhaul.
It also doesn’t have side covers on the block like some of the older or larger Caterpillar engines have, so you have to drop oil pan and do everything from the bottom. Not sure what a 943 charger is, but if you are willing, there’s usually a way! Problem is your cylinders probably will need boring to an oversize and install pistons and rings to match if you want your repairs to last. This is done in machine shop, so engine out for that and do the assembly on an engine stand where you can stand up and work on it.
Thu, Jan 16, 2020 7:32 PM
uisum
[quote="ccjersey"]3204 doesn’t have cylinder sleeves unless it’s been bored out and dry sleeves installed in a machine shop during a previous overhaul.
It also doesn’t have side covers on the block like some of the older or larger Caterpillar engines have, so you have to drop oil pan and do everything from the bottom. Not sure what a 943 charger is, but if you are willing, there’s usually a way! Problem is your cylinders probably will need boring to an oversize and install pistons and rings to match if you want your repairs to last. This is done in machine shop, so engine out for that and do the assembly on an engine stand where you can stand up and work on it.[/quote]
Hello .
I disassembled the head.
The seal was melted between pistons 2 and 3.
Pistons 2 and 3 have a melting angle, I think they need to be changed.
On cylinder number 3 the triangle (about 3mm) lost by the piston has melted in the cylinder itself.
For sure the bands are very damaged
That's why all that smoke from the oil drain.
Precautions to replace pistons?
Thanks so much
Simo
Fri, Jan 17, 2020 1:01 AM
Reply to uisum:
Hello .
Thanks so much
Simo
I knew it, I just knew it, woof woof, woof woof"
Fri, Jan 17, 2020 2:28 AM
Either send the block to a shop to be bored for oversize pistons or AT LEAST....remove the ridge at the top of the cylinders and then hone them to allow the new rings to seat properly.
Failure to ream the cylinders to remove the ridge usually results in damage to the piston and new top ring when it contacts the ridge that has been left by the worn rings. Reaming the ridge also helps get the old pistons out without damage but it sounds like you need new ones anyway.
Replacement of ALL bearings on the crankshaft is probably a good idea. Or check clearances carefully and only reuse if the clearance is within the Caterpillar recommended range. I personally would not reuse a connecting rod bearing unless it was nearly new and showing minimal wear
Head should be resurfaced and checked for cracks as part of the reconditioning process and valve grind.
The most likely cause of the burned pistons is bad injectors, so do not fail to have them checked for proper spray pattern and pressure setting.
Fri, Jan 17, 2020 3:51 AM
uisum
[quote="ccjersey"]Either send the block to a shop to be bored for oversize pistons or AT LEAST....remove the ridge at the top of the cylinders and then hone them to allow the new rings to seat properly.
The most likely cause of the burned pistons is bad injectors, so do not fail to have them checked for proper spray pattern and pressure setting.[/quote]
Hi I removed the pistons, one was quite damaged. It is striped on the upper side.
It seems that the detonation took place in the outermost part and melted a small portion of the piston.
I don't have much experience, but as you say it seems a problem of incorrect atomization of the injector.
The cylinders are completely mirror smooth.
The cylinder head is undamaged, the engine has 5100 hours.
Now do I have to remove the injector, do I have to change it completely or can I only change the sprayer?
Thanks for your help .
Simo
Sat, Jan 18, 2020 2:23 AM
Reply to uisum:
Simo
Buy new complete nozzles from Cat, to be extra sure ask if they can test them, I have gotten some for a 3208 and some were bad. Better to just pull the engine and rebuild it or get an exchange engine.
Sat, Jan 18, 2020 3:21 AM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
