Twenty Two clutch component availability
Showing 1 to 10 of 17 results
Thank you received: 19
I'm looking at replacing 1J3796W's clutch plate, thrust bearing, clutch brake (lining), and pilot bearing when I head to the old country next year. Would any owners happen to know if Cat has these available (I'm sure the bearings will be) or aftermarket? This is prompted by the old clutch plate getting stuck to the flywheel/pressure plate and so if a bronze plate was available, that would be even better. If this works out, I might get the crank and babbitting done at the same time since it badly needs it
Tue, Jan 14, 2020 1:23 AM
If the steel plate is not severely heat cracked just have a machine shop resurface it. Check with Arts Parts on the friction plate 1-614-565-0506
Tue, Jan 14, 2020 1:42 AM
Peter C
Send a private message to Peter C
Neil, I just this morning got a call from Caterpillar that the thrust bearing (part # 4B3665) and pilot bearing roller assembly (part # 1B3739) that I ordered were ready for pickup. As I remember, the approximate cost of the thrust bearing was $37. I didn't ask for the cost of the pilot bearing. The pilot bearing did not come with the outer race which wasn't available. I didn't need the other parts that you mentioned so I can't help you there.
Regards.
Pete
Tue, Jan 14, 2020 3:55 AM
Reply to Peter C:
Regards.
Pete
Thanks all
Tue, Jan 14, 2020 4:11 AM
MARCOTEN
Thanks all
For my fifteen which is probably the same as 22 i used this bearing : Skf 6209 2Z closed greased filled.so always lubricated.
Is the lining complete gone of the brake disk? I did put 2 komp glue and new rivets in it as it was loose.
There is a good video on u tube of squatch 253 about a ten getting new clutch bearing.
Tue, Jan 14, 2020 6:21 AM
Reply to MARCOTEN:
Neil, I took my clutch disk and clutch brake to my local truck service center and they re-lined them for me, no problem. As for the bearings, I just looked for the numbers on the old bearings, and did a Google search. If I recall correctly I got them both on ebay. Good luck. Ray
Wed, Jan 22, 2020 9:56 AM
bruce oz
throwout bearing, 4B3665 crosses to Fafnir 209K, Federal 1209, MRC209S, etc
Wed, Jan 22, 2020 10:20 AM
Reply to bruce oz:
Thanks guys. Ray, what thickness did you tell them to attach to the clutch plate (per side)?
Wed, Jan 22, 2020 7:35 PM
Norm R2,22
Send a private message to Norm R2,22
Neil, I just measured the friction material on the 22 clutch I have, it is .165". The total of both frictions and metal dick is .485". It looks as though the fellow I bought the tractor from had just had it redone. The tractor was purchased in pieces and is all over the garage and shop. Hope that helps.
Wed, Jan 22, 2020 11:27 PM
Reply to Norm R2,22:
That's great info, thanks Norm!
Thu, Jan 23, 2020 12:01 AM
Neil,
I can't recall for sure, but I think I told them to make it 1/4" after I discussed it with them. Same for the clutch brake. I put in new throw out and pilot bearings.
Ray
Mon, Jan 27, 2020 5:27 AM
Newby Hall Tractor Fest
