d2 3j3054 cracked crown wheel shaft
Showing 1 to 10 of 30 results
Nick22australia
Send a private message to Nick22australia
Hi all
I started cleaning up the parts today for the back end of my d2 and I noticed there is a crack on the tapered spline part of the shaft where the right hand side steering clutch hub.
I made a couple of calls today for a replacement but had no luck.
I was thinking if got desperate I could V out the cracked area and fill it with my mig welder then take the time to regrind the taper and the splines back to a satisfactory standard for a machine that's only really for show anyway.
Does anybody out there have any better ideas or knows a reason not to touch it with the welder?[attachment=56687]IMG_2300.jpg[/attachment]
Tue, Jan 7, 2020 8:21 PM
STEPHEN
[quote="Nick22australia"]Hi all
Does anybody out there have any better ideas or knows a reason not to touch it with the welder?[/quote]
Keep looking and advertising. That problem is too deep into the machine to gamble.
Tue, Jan 7, 2020 10:12 PM
restore49
Reply to STEPHEN:
what is the part #
Tue, Jan 7, 2020 10:32 PM
Nick22australia
Reply to STEPHEN:
Yeah that’s the problem,no quick fix if it were to fail
Wed, Jan 8, 2020 7:37 AM
Nick22australia
Reply to Nick22australia:
Part number is 4B3704
Wed, Jan 8, 2020 7:39 AM
Thats the same number as in D2 5U1-13237 tractors, should be some good used ones around.
Wed, Jan 8, 2020 7:48 AM
OzDozer
Nick, that shaft is completely shot, you won't be able to fix it with weld. You need to find a good used replacement shaft.
Try Wilson Wrecking in Torbay (West of Albany), or Davey Jones at SwanTrax in Hazelmere.
The proper Cat name for the crown wheel is the bevel gear, and the shaft is the bevel gear shaft.
Wed, Jan 8, 2020 8:17 AM
restore49
Reply to OzDozer:
2F1775 is not the same part ( short 11 1/2") ? Bob
Wed, Jan 8, 2020 8:46 AM
Hutchy
Send a private message to Hutchy
Hi Nick,
Just throwing some ideas a round, does the threaded hole in the end extend past the crack and into the center section of the shaft? I’d be game to install the hub on the taper tightly but only if the bolt can hook up past the crack. The angle of the break and the force of the hub on the taper may be enough to get you around as a show tractor. I’d be hesitant to put it to work but it might save you the hassle of finding the parts here in oz. We don’t seem to have the parts availability the boys in the US do for these little gems.
I feel the heat generated by welding would probably weaken the shaft and you’d be worse off.
It depends on weather you like to gamble a bit or not 😂😂
Good luck
Hutchy
Wed, Jan 8, 2020 3:41 PM
gemdozer
Thank you received: 11
Reply to Hutchy:
Hi Nick,
Good luck
Hutchy
I am still have a bevelgear shaft 4b3704
Thu, Jan 9, 2020 2:56 AM
BigAgCat
Send a private message to BigAgCat
Reply to Hutchy:
Hi Nick,
Good luck
Hutchy
If I had the tools and the knowhow, Also the realization I probably have nothing to lose, I'd consider removing the shaft, getting its dimensions, and finding a nice piece of metal to mill into a replacement shaft. Or maybe just cut off the spline end weld a new piece of metal on there and mill out the splines.
Fact is, there is a limited number of these old tractors that were built. Spare parts will dry up, and good ones at that. It means that either these tractors will ultimately have to be put to rest or people need to start actually fabricating new replacement parts for them in order to keep them running.
These aren't like Honda civics or Toyota Corollas where basically everyone has or had one. I think the numbers built of most of these tractors range in the thousands or maybe tens of thousands at the most.
Technology today is amazing. A person could do a 3d rendering of any part of these old tractors with just the measurements and could easily replicate the parts.
Cat D6 5R
Thu, Jan 9, 2020 3:10 AM
