Happy New Year everyone. This is a followup to a post I had in November in which I had a couple of questions, one related to a leaking fuel supply line at the adapter to the transfer pump. I'm posting this in a new thread because I'm expanding the question. Sometime in the past, the original fuel line from the tank was replaced with 1/2" copper tubing, and the ferrules were soldered onto the ends. Question 1 - I believe the ferrules are the original Cat type, can anyone confirm?
When I tried to shut the fuel off at the tank valve, the valve started leaking around the packing. I tried tightening, but it did not stop the dripping. Question 2 - is this an original Cat valve or an aftermarket replacement? When I took the valve apart, I noticed scoring around the walls of the valve. I'm concerned this would not allow a proper seal to shut the fuel off completely. Question 3 - should I replace this valve or is it repairable (or ok to use as is)? If I replace, I'd like to find something a little more compact.
I'm considering adding a pre-filter since many have recommended this and there was a lot of sediment in the valve when I took it apart. I've read a couple of threads related to this including this one from 2010 (
http://www.acmoc.org/bb/showthread.php?8368-Pre-Fuel-Filter-for-a-Cat-D2) in which Cysco, Old Magnet, and others in which this was discussed, and Cysco decided on a Wix 24309 base. I'd rather mount this near the seat tank area vs near the starter pinion of possible. Question 4 - Since this was 10 years ago, is there a more compact/better pre-filter available or is this one recommended?
I'm considering changing the copper tubing to -8 flexible hose to allow for a better fit and easier install. I stopped by a hydraulic hose shop a couple of days ago and asked about stainless steel braided hose with the teflon lining. During our discussion, he mentioned a cheaper alternative, which was a reinforced rubber hose that was rated for diesel fuel, called 801 hose. I'm still leaning towards the SS braided line, but I'm confused on the ends that I need crimped on. They use Parker hose and fittings, and there seem to be all kinds of fittings available, including -10 fittings to go on -8 hose. In the post I referred to above, OM mentioned that he uses a -10 o-ring boss adapter on his machine, but also mentions a JIC 37 degree fitting as an option. Question 5 - is the Cat flange inside of the adapter a 37 degree flange, and if not, is it close enough to give an adequate seal? Question 6 - would the JIC 37 degree fitting be the preferred fitting for the transfer pump adapter, and if not, what would be the best fitting to replace the original Cat ferrule?
[attachment=56554]15F931BE-25B7-41FD-B1FC-743BD92DE470.jpg[/attachment][attachment=56555]8E852715-BBE4-47D5-BB54-1724A3AF2F4F.jpg[/attachment][attachment=56553]645A03B7-DA87-4A94-A49D-8BEE318A75C3.jpg[/attachment][attachment=56552]548D42F4-D746-4572-B195-25119D385270.jpg[/attachment]
