D2 Starter Pinion Latches
Showing 1 to 10 of 22 results
Cat Yellow1
Send a private message to Cat Yellow1
Since I’ve owned my D2, I’ve had to hold the starter pinion in gear until the Diesel engine starts, and if I let go before it starts, it disengages. While I have the pony out being overhauled (waiting for my block and crank from the machine shop), I figured I might as well go ahead and fix it now. The stop appears to be in good shape, and looks like it may have been turned over at one point. The latches look worn to me and I’m probably going to replace them. I’ve attached photos for anyone who wants to chime in on whether or not they should be replaced (I know they’re not cheap but want to fix it right).
[attachment=56360]A6AF7C8E-AE0E-4361-82F5-95C20341D2D4.jpg[/attachment][attachment=56361]53B3B362-0304-484D-B021-19743EDA6993.jpg[/attachment][attachment=56362]4208A81E-496D-41E4-B46B-0EFAC697CC83.jpg[/attachment]
Thu, Dec 19, 2019 2:45 AM
Cat Yellow1
Also, when I removed the adjustment screws, both were in 4 and a half turns.
Thu, Dec 19, 2019 2:57 AM
Reply to Cat Yellow1:
I would just preheat the worn spots and weld them up [latches] with 7018 and grind back to shape.
Thu, Dec 19, 2019 4:03 AM
Cat Yellow1
Thanks Rome. That's a good idea, but I don't have the capability to do that at the moment. I went ahead and ordered from Florin.
Does 4 and a half turns sound like the correct position on the spring tension screws?
Thu, Dec 19, 2019 6:11 AM
wimmera farmer
If you have been holding it in for quite while there may be wear in other places as well. The engagement mechanism is not meant to be held in all the time.
Thu, Dec 19, 2019 8:02 AM
[quote="Cat Yellow1"]Thanks Rome. That's a good idea, but I don't have the capability to do that at the moment. I went ahead and ordered from Florin.
Does 4 and a half turns sound like the correct position on the spring tension screws?[/quote]
I'm not sure, there was a thread on here about that, I thought it was flush with the collar then in two and a half turns.
Thu, Dec 19, 2019 8:28 AM
BigAgCat
Send a private message to BigAgCat
I don't know if all ponys are the same on all tractor sizes, but my book for a D6 says that for every turn, the release RPM is increased by 100-150 RPM. I assume the starting point is where you can put the cotter pin in.
The pinion gear for my tractor is 13t and the flywheel gear is 112 t. So, every 1 turn of the pinion gear means about 0.12 turns of the flywheel gear. So the diesel turning at 1500RPM would cause the pinion to turn at a rate of 12,500RPM if it stays engaged. I don't know if it is basically a 1:1 ratio of RPM from the starting engine and starting clutch and pinion, but my pony motor is rated at 3000RPM, so a stuck pinion may possibly cause the pony to start rotating at 12,500RPM which probably wouldn't be a good thing. Even at the lowest idle speed of the diesel, you may be overspeeding the starting engine.
On the other side, if the ratio is 1:1 on the pinion from the starting engine, a pony running at 3000RPM is going to be rotating the diesel at 360RPMS. So if the RPM increase is 100-150 per screw rotation, then 2.5 turns gets you 250-375RPM release speed and 4.5 turns gets you 450-675RPM release speed.
I don't know if this is how the relationship is completely defined, but it looks like 2.5 turns guarantees your starting engine won't be overspun when the diesel engages while 4.5 turns would put you at risk of overspinning the starting engine. 450RPM would translate to spinning around 3,750RPM in the starting engine. 675RPM means 5,625RPM. Sometimes cylinders in the diesel fire while others don't during starting, which would overspeed the pinion causing it to pop out. So, if you pick 4.5 turns, you may end up overspeeding your pony while trying to start the diesel.
However, this is for my D6 and it may or may not translate exactly to a D2.
Cat D6 5R
Thu, Dec 19, 2019 9:24 AM
D4Jim
Thank you received: 5
Reply to BigAgCat:
I robbed this off a post some time back and it gives the dimensions for one of the latches. I had problems with a pinion several years ago unlatching and I replaced the latches and spring and that cured it. I think the face of the latch is quite critical and the dimensions bear that out. It would take a machinist with a lot more accuracy than me to weld up the latch face and grind it back. There is a slight taper to the face and I think it is quite critical. Ponys are great when they latch and unlatch correctly but otherwise can be a PITA. Bought latches in 2005 for $77 each and I believe the local Cat dealer said they are now about $250 each..
Cats Forever
Thu, Dec 19, 2019 9:50 AM
Cat Yellow1
Reply to D4Jim:
Jim - that's pretty interesting. Glad I bit the bullet and went with new ones. I believe they are 275 now from Cat, but I got mine at Florin for less than half of that.
BigAgCat - When I removed the adjustment screws, both were 4 and a half turns from the point where the threads engaged. Rome mentioned 2 and a half turns from the point the screws are flush with the collar, so we might be talking about the same thing. I ordered a new spring also, so I might set them initially to get the cotter pin set and adjust from there.
Thu, Dec 19, 2019 6:46 PM
d2gary
im with Rome K/G weld them up. I dont think this is a machinist part, close is close enough especially 60 years later. Refurb and adjust properly and you'll be good to go. I've adjusted a couple and I'd start on the loose side, cause its alot easier to adjust than rebuild.
Fri, Dec 20, 2019 10:55 AM
d2gary
Reply to d2gary:
At 4 and a half turns I'd say your spring is weak. I replaced 1 spring and it made a huge difference. All the others I've worked on where just out of adjustment
Fri, Dec 20, 2019 10:58 AM
Chapter 2 The Link Club's AGM
