I did not think cat made a self propelled grader model 22. I saw an auction ad for two 22 graders one diesel and one gas. Obviously that must be incorrect. I am looking for a D3400 engine and thought I would atleast check to make sure a 22 wasn't an early 212 or something.
Thanks.
hello mkreh23,maybe when they looked out the window from the office they seen 212 ,lol with 1 faded,212 is the closest number come to being a 22 ,bruce oz
My archive came up with a 22 with a grader on it, whether the grader is Cat or not I don't know, I did have some colour pictures of a 22 grader but can't access the cd they are on due to a new cd writer been a different format.
AJ
The grader in you pic is a 15 look at exaust coming out of right side curtain The only Cat 22 equip made was 22 tractor 2F&1J,22 teracer 4H and the 22 Pull Grader 3H
That could even be a 2ton
here is a scan from my Former Model Specs. No11, Form 10898-03, March 1 1954.
Hope this helps.
Hi, Mkreh23.
Russell (swallowed by Cat.) made several models of grader to suit various crawler tractors where the tractor was actually driven into the grader and pinned/bolted/clamped in place. The crawler tractor then became both the power plant and the drive for the grader. I do know that they made them for the Ten and the Fifteen and I'm pretty sure they made them for one or both versions of the Twenty.
I suspect that by the time the 22 was introduced, the current wisdom was that self-propelled graders were the way to go. That how-wevver didn't stop them from making a side-saddle modification for the 22 so that the operator could better see his drawn grader which I seem to remember was sometimes powered by the crawler's PTO and controlled from the tractor.
